Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-29-2020, 01:05 PM   #1
Bullett
Clear coat truck prep
I want to scuff my truck, touch in a couple small spots and then put a coat of new clear coat over the whole truck. My question is, what is the safest and finest grit I can use to scuff the truck down with that the new clear will adhere to. Thanks.
Bullett is offline   Reply With Quote
Old 03-29-2020, 02:22 PM   #2
trixter99
I have no time for this
trixter99's Avatar
Re: Clear coat truck prep
I’ve dry sanded with 900 on a orbital and had no issues. Wet with 1000 will be fine as well. Is your truck clear coated already?
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 03-29-2020, 03:11 PM   #3
Bullett
Yes, had a well known body shop put a new b/c paint job on it a couple years back. Even though I specifically asked to leave it as it came out of the spray gun, that’s not what I got. He wet sanded and buffed it. It looks great in the shade. In the sun, there are deep buffing swirls all over the truck. I do body work and paint as a hobby, but was laid up at the time with health issues so I had him do it. I’ve since tried every which way and every suggestion to try and remove the swirls. They just aren’t coming out. I want to scuff and put one good coat of clear over it and be done. I can paint, it will look good. I have just never done this and wasn’t sure what I could get away with for wet sanding and still have enough tooth for the new clear to adhere to.
Old 04-01-2020, 10:25 PM   #4
Myself
Why not just cut it with 1000 grit and polish it back out? There should be plenty of clear on to do it.
Myself is offline   Reply With Quote
Old 04-02-2020, 12:01 PM   #5
MDPotter
MDPotter's Avatar
You should look at the tech sheet for whatever clear you're planning to use. If it were me, I would use SPI Universal Clear and sand with 600 prior. I know it costs more, but you should do two coats. That will give you peace of mind that you have good mil thickness and in case you ever want to cut & buff yourself you have enough.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 04-02-2020, 12:19 PM   #6
67swb72klb
67swb72klb's Avatar
I would try buffing again maybe go with a more aggressive compound or pad.
Make sure you change pads when you go to the lighter compounds
Good luck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 04-02-2020, 10:00 PM   #7
Skymortar
Wet DA it with 3m 300 grit trizact and buff it again
Skymortar is offline   Reply With Quote
