02-22-2020, 06:07 PM | #1 |
Carpe manana
WTB: Eaton rear axle locker tag
Hoping to find a locker tag for an Eaton rear axle like the one shown below (borrowed from Stovebolt.com).
Buy or trade. Thanks.
02-26-2020, 06:29 AM | #2 |
DND Trucks
Re: WTB: Eaton rear axle locker tag
Hi Pete,
Couldn't you make one I've got a HO52 no spin with the tag, nothing stamped on it though Do you need dimensions |
02-26-2020, 08:27 AM | #3 |
Moderator
Thats what I did to include the current ratio.
02-26-2020, 09:11 AM | #4 | |
Carpe manana
Good idea. I swapped out my front axle tag on the Blazer when I added 3.73s.
02-26-2020, 09:49 PM | #5 |
Hmmm....69-72 positraction rear ends had a red plastic tag so not sure what the metal tag is supposed to be?
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
02-26-2020, 11:13 PM | #6 |
Carpe manana
Correct - for an entirely different axle in 1/2t applications though. This tag is found on Eaton rear axles with No Spin lockers used for 3/4 and 1 ton trucks not only for 67-72 but for many preceding model years from what I understand.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 02-26-2020 at 11:25 PM. |
02-27-2020, 07:34 AM | #7 |
hi Pete, I've posted this several times because it was so surprising that the tag being present is the tell, there's nothing on it from the factory..
I have one loose I can possibly even make you one or anyone else [within reason] and send them to you.. I have some crafty mechanics at work that can probably match the material and figure out how to stamp or cut some out.. it's laying there in the yoke..... from my fruitless search for what was printed or stamped on it
I started out with nothing - and I still have most of it |
02-27-2020, 07:46 AM | #8 | |
and ratio tags with tooth count.. these tags on 4wd D44 front axles are also somewhat reliable tell for rear gear ratios where the rear HO52/72 isn't as easily distinguishable
02-27-2020, 09:51 AM | #9 |
Carpe manana
Anything I can do to facilitate a reproduction please let me know. Tiny details like this I’m all about. Thanks for taking the time to post pics.
Here’s an example of what the posi tag would look like for a 12 bolt on a half ton truck for at least 71-72 and probably earlier. Note the coarse plumbing threads and shape of the bolt - totally different design than found on an open diff rear, which use a finer thread and have a recessed slot to accommodate a socket wrench.
02-27-2020, 09:56 AM | #10 |
Carpe manana
Here’s a NOS locker not same model as seen in light duty trucks but note the envelope has instructions to the chassis assembler to leave instructions in the glove box and affix the decal to the instrument panel.
02-27-2020, 11:02 AM | #11 |
K B,
I would like two, if I am not too greedy, thanks Have two C20 trucks w/HO52s, both 4:10 and locker. Really like how they look HD. 66’ C20 CC, 327, turbo 400, ....... 64’ C20 COPO 327, BBW,...... Les Last edited by aotte1; 02-27-2020 at 11:07 AM. |
02-27-2020, 01:46 PM | #12 |
Gotcha - I only know one man who'd likely have one so I will ping him now and see
02-27-2020, 09:19 PM | #13 |
DND Trucks
Pete,
Got some measurements for you and pics. Thickness is .060 with overall length at 2.25, width is a symmetrical oval shape with the center being 1.25 at its widest and the hole is .625 or 5/8 I can make this for you if you'd like. It's about 15 minutes of work. Just need a address to ship it . |
02-27-2020, 10:02 PM | #14 |
Carpe manana
You are the best! I’d love to have one and more than willing to compensate you for your time. If I had means to do so I’d produce myself. Happy to send beer money for your effort and am in no rush.
02-27-2020, 11:11 PM | #15 |
DND Trucks
It'll be done tomorrow. Just PM the address to me and I'll send it you.
02-28-2020, 12:42 AM | #16 | |
I checked mine this morning and I thought it was .030" - .031" which would be about 22ga.. I'll double check that.. it's carbon steel and rough dimensions I took are same, about 1.25" x 2.25".. pinion cover bolt is .500" so clearance hole maybe slightly larger, lock washer didn't leave clean hole on mine to be precise but never see it after installed Les is also looking for a couple per post #11, could you make them for him too please? I don't mind making some but you'll certainly be done before me thank you!
02-28-2020, 09:22 AM | #17 |
Carpe manana
Super kind of you Dave - PM sent. Thank you.
KB - big thanks to you too! Great folks here on the forum.
02-28-2020, 01:56 PM | #18 |
^ indeed Dave, very kind!
I wonder if they're were any changes to these over the years or models? either way, I like the thicker material as these are somewhat fragile as seen here the lightly cleaned tag I removed from diff with ring gear date 4/1970 is ~ .030" the rusty wrinkled tag still on the original diff in the red '71 longhorn is ~ .035"
02-28-2020, 06:04 PM | #19 |
DND Trucks
02-28-2020, 09:09 PM | #20 |
Carpe manana
I can’t thank you enough. Very kind. Thank you.
02-29-2020, 01:46 PM | #21 |
Dave,
PM sent Les |
