Old 07-16-2019, 09:20 PM   #1
72 k15
72 k15's Avatar
Best 1959 GMC disk brake conversion kit?
Who makes the best 1959 gmc disk brake kit? Want better brakes just got the truck pulls to the right hard when braking. Do you need a new master cylinder?
Thanks new to the 55-59 trucks
1959 GMC 100 3 on the tree 270.
1968 GMC k2500 Stepside
1972 Chevy Monte Carlo Custom.
72 k15 is offline   Reply With Quote
Old 07-16-2019, 10:45 PM   #2
Quindel3100
Re: Best 1959 GMC disk brake conversion kit?
Pulls to the right...check your front brakes, shoes may be worn out,wheel cylinder maybe seized(left side) or right side leaking. Or all brakes out of adjustment. If your pull is not really felt in the steering possible issues in back brakes. It's cheaper to fix the brakes you have on the truck than to replace the whole setup. Going to disc brakes is a worth while endeavor,however,you will be able to fix it up and have working brakes while you do your research. I cant give you an answer on best vendor,there are many options so do your homework well.
Quindel3100 is offline   Reply With Quote
Old 07-17-2019, 12:20 PM   #3
_Ogre
_Ogre's Avatar
if you still have the original axle just fix the existing drum brakes, they worked fine for the last 60 years
shop air compressor timer
Old 07-17-2019, 02:52 PM   #4
72 k15
72 k15's Avatar
Good point think ill just rebuild the entire braking system on the truck. PO put in a new master cylinder.
Old 07-17-2019, 05:43 PM   #5
Quindel3100
Bleed the brakes. Air in the system will give you a pull.
