Old 11-14-2008, 03:49 PM   #1
68 longbed
Question cadillac rear disc brakes on 70 truck
Another question for you guys I,ve heard you could put cadillac rear disc brakes on our model trucks. Is anyone done this and could maybe tell how it,s done? Also maybe show some pictures?
68 longbed is offline   Reply With Quote
Old 11-14-2008, 05:49 PM   #2
john
member #16
john's Avatar
Re: cadillac rear disc brakes on 70 truck
Heres a link to a CCP article.
http://www.classicperform.com/tech_a...kes-trucks.htm
john is offline   Reply With Quote
Old 11-14-2008, 08:20 PM   #3
68 longbed
Is there a way to do this without buying a kit? Maybe use rotors and calipers off the cad?
Old 11-15-2008, 01:56 AM   #4
shaneschevys
Its always something!
shaneschevys's Avatar
I am using a 76-79 seville rear under my 72. It keeps the 5in bolt pattern & is already set up to sit on top of the leaf spring.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 11-15-2008, 03:42 AM   #5
tdave00
Restoring a 68 SWB
tdave00's Avatar
What gear are usually in the Seville's, and is the rearend the same width?
tdave00 is offline   Reply With Quote
Old 11-15-2008, 05:28 AM   #6
61superman
61superman's Avatar
i am currently using 1986 caddy seville disc brakes in the rear of my 72 burb. kept same 5 lug pattern and still running mid 80's steel wheels.
86 seville had rear disk brakes that uses rubber brake line with a 10mm x1.50
banjo bolt.
i am using stock 72 burb rear end with the caddy backing plate and brake setup. the only problem you will have is the parking brake cable but, POL (performance online.com) has solved this issue and makes the correct lenght cable when using caddy disc brakes. I pieced my setup together, but POL makes a kit for 67-72 trucks to run caddy rear disk brakes.
current project: 1964 chevy II Wagon
1956 3100
1972 c10 burb bagged
1962 GMC burb
1963 c10 burb
1966 c10 burb
1995 chevy lowerado 5/7 static drop daily driver
1963 c10 step side
1965 super sport impala
1967 c30
61superman is offline   Reply With Quote
Old 11-15-2008, 12:37 PM   #7
68 longbed
61 Superman do you have any pictures? This is more of what I,d like to put on mine.
Old 11-15-2008, 09:13 PM   #8
61superman
61superman's Avatar
68 longbed i have none as of now but i will try to take some pics tomorrow.
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 11-15-2008, 10:22 PM   #9
Ram-Man
Ram-Man's Avatar
If you dont care about an e-brake you could use the impala set up or if you do want and e-brake you can use the camaro calipers. Here are a couple pics of my impala setup.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 11-17-2008, 07:39 PM   #10
68 longbed
Ram-man what year impala brakes you using?
Old 11-17-2008, 09:05 PM   #11
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I have rear discs off a fleetwood, I think it was a 76 or something
I havent gotten them installed yet, but as far as I know its pretty strait forward & you just swap the backing plates for the caliper bracket & bolt the rest of the disc stuff on
Also this may help you find some discs, its a list of 5x5 compatibility
http://67-72chevytrucks.com/vboard/s...d.php?t=234769
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-17-2008, 09:41 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Isn't the early Seville based on the same era Nova? Not that it matters, mind you. I'm just trying to reach back into some of the cracks and crevices of my damaged brain for some tidbit of trivia.
Member Nr. 2770
Old 11-17-2008, 10:32 PM   #13
Ram-Man
Ram-Man's Avatar
Mid 90's rotors and calipers. The cores for the calipers are expensive so try to hunt some old rusty ones down to turn back in for the core charge.
Here is an old thread on this.
http://67-72chevytrucks.com/vboard/s...ghlight=impala
Old 11-20-2008, 05:32 PM   #14
68 longbed
superman did you get those pictures yet?
Old 11-22-2008, 03:08 AM   #15
61superman
61superman's Avatar
68 longbed i apologize brake booster went out and been working sick overtime trying to support my habit will try extremely harder this weekend
once again i apologize
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 11-23-2008, 07:17 PM   #16
68 longbed
Superman didn't mean to rush you. I'm trying to make up my mind on which way to go caddy (which I'm leaning towards)or the impala route.Caddys are more pleneful in this area.
Old 12-01-2008, 08:01 AM   #17
61superman
61superman's Avatar
alright 68 longbed again i apologize but here is what you were asking for:
this is my setup
85 cadillac seville calipers stamped 020,021
77 cadillac seville rear rotos (mine are just drilled)
banjo bolt 10x150
the cadillac rubber brake hose is metric for it to bolt up to your hard line you will need an adapter from metric to standard (got mine from napa).
hope this helps and if you have any questions i promise to get back with a speedy response.
hope the wait was worth it
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 12-01-2008, 11:53 AM   #18
suville
suville's Avatar
What application is the caliper mounting plate from? And does it bolt right up to the backing plate flange? Thanks
suville is offline   Reply With Quote
Old 12-01-2008, 12:29 PM   #19
justcuz
justcuz's Avatar
Post #6 says he is using the Caddy backing plate, actually the entire Caddy setup. With an aftermarket parking brake cable and adapters for the brake line.
justcuz is offline   Reply With Quote
Old 12-01-2008, 03:13 PM   #20
61superman
61superman's Avatar
i am using 79 deville mounting brackets also i need to mention that the seville and deville rotors are the same for a number of years therefore can be interchangeable. as i was developing this brake setup there are several possibilities to choose from these are just what i had lying around and scavenged from friends.
here are some of the part numbers that i have that are stamped in the metal are:
1610797 rotors (stamped on back)
1613827 brake mounting bracket (stamped on front)
020 and 021 calipers passenger and drivers
these numbers are gm specific
final note: again this is just what i went with, please research info before spending time and money on your brake setups
good luck
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 12-01-2008, 04:14 PM   #21
nartkers
nartkers's Avatar
Any idea where to get those brackets? Besides the junkyard?
nartkers is offline   Reply With Quote
Old 12-01-2008, 04:54 PM   #22
61superman
61superman's Avatar
i called chevy dealer and they said that they were no longer available. thats about the only way i know. CPP and POL both have kits that allow this type of setup they might just sell that mounting brackets wouldn't hurt to ask them. here are some other options:
good luck
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 12-02-2008, 04:24 PM   #23
68 longbed
this is my setup
banjo bolt 10x150
Hey! Thanks 61 Superman. I just have 1 more question which thickness rotor are you using. In my junkyard hunting I seen 2 different thickness rotors, one 1/2 inch the other roughly 1 inch.
Old 12-02-2008, 04:48 PM   #24
61superman
61superman's Avatar
the rotor is about an inch thick
good luck
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 12-02-2008, 05:12 PM   #25
MickMc
MickMc's Avatar
79-85 Eldorado, Riviera, and Toronado and 80-85 Seville.
Piston Diameter 2 1/32. Opens to 1.050. 5 1/2 inches pin to pin.
BENDIX Part # L55312
Rear Left Caliper with Pad; Contains CQ ceramic pads $91.79 $15.00 $106.79
BENDIX Part # L55311
Rear Right Caliper with Pad; Contains CQ ceramic pads $91.79 $15.00 $106.79
Maybe this helps
www.rockauto.com
Mick
MickMc is offline   Reply With Quote
