Old 09-22-2020, 05:29 PM   #1
RADustin
Lap Seat Belt Buckle
Has anyone rebuilt them before?
Mine don't seem to be grabbing the belt very much. Or the button appears to be kind of frozen. Just generally appear to need to come apart and be tuned up.
They are lap belts from a '76 crew. Original belts and buckles.
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 09-22-2020, 07:05 PM   #2
TKCR
TKCR's Avatar
Re: Lap Seat Belt Buckle
There is probably something shoved in there. I just had one on a metal buckle cover that I was replacing, because of the rust. But when I popped the cover off, there was gum wadded up in the wrapper inside the buckle.I haven't ever taken the cover off ones like yours, but I bet they come off the same way, because they have replacement covers just like the metal ones.
Old 09-22-2020, 07:22 PM   #3
TKCR
TKCR's Avatar
I just went out and got one off. Just take a small flat head screwdriver and work your way around, prying lightly and lifting the plastic buckle from the metal part.
And you can see there is something in this one too.
Old 09-23-2020, 11:40 PM   #4
85/Silverado
85/Silverado's Avatar
I have a complete set of that color If you need them, came out of my 85 silverado just need cleaning. Just reimburse me the shipping. I'll post pictures tomorrow.
85 Silverado LWB Fleetside 383 Stroker
86 Custom Deluxe SWB, Pro Street LSX
85/Silverado is offline   Reply With Quote
Old 09-23-2020, 11:54 PM   #5
RADustin
yall are awesome!!
1949 Chevy 3100 P/U
Old 09-24-2020, 08:50 AM   #6
TKCR
TKCR's Avatar
The 85 belts won’t look like his. Totally different belts and retractors.
78-87 belts are like the 1st pic.
73-78, which is what he has, look like the 2nd pic.
Old 09-24-2020, 09:31 AM   #7
RADustin
yep 2nd pic is what I have.
you're saying I have to cut off the metal buckle to get the plastic cover off?
Looks like the roll up mechanism is held together with some heat set plastic. I would if I take that off if I can take apart the roll up mechanism and take it apart that way.
On the front belts, is it possible to reset the spring if I pull the mechanism all apart?
1949 Chevy 3100 P/U
Old 09-24-2020, 09:35 AM   #8
TKCR
TKCR's Avatar
All you have to do is use a small flat head screwdriver to pop the plastic buckle cover off. It’s simple. I just did that one in the above pic in less than a minute. And yes, everything will reset back together.
Old 09-24-2020, 09:41 AM   #9
TKCR
TKCR's Avatar
You can also send your entire set to me to restore. I have done a couple like yours.
Old 09-24-2020, 09:46 AM   #10
RADustin
I was mostly asking with regard to the roll up mechanisms. You had mentioned I have to remove the belt buckle tang to change the plastic cover piece that is broken.
I know you restore these things, I'm not trying to step on your toes in any way.
1949 Chevy 3100 P/U
Old 09-24-2020, 10:03 AM   #11
TKCR
TKCR's Avatar
That was on another thread. https://67-72chevytrucks.com/vboard/...d.php?t=812302 You were asking about the retractor cover. That you would have to remove the metal latch, the one that buckles into the buckle itself. Those covers will not come off without removing the metal latch.
This particular thread is about removing the buckle cover, which I answered. Small screwdriver.
Old 09-24-2020, 10:32 AM   #12
RADustin
sorry for the confusion. I got all the buckles apart.
1949 Chevy 3100 P/U
Old 09-24-2020, 11:14 AM   #13
RADustin
I popped all the roll up mechanisms off, so everything is apart. The back springs will be fun to rewind but nothing major. Thanks for the help.
1949 Chevy 3100 P/U
