12-30-2018, 06:44 PM | #1 |
Engine Stands
Little back story. 69 GMC swb that left factory with a 307. When I bought my truck many years ago it had a 454. So, I’m assuming that the PO put in BB stands. After that, I swapped in a carbureted LT1 and reused the stands that was in it. About 2 years ago, while I had my truck stored with a friend I had him put in a 350 crate engine pulled out of a 90’s Chevrolet pickup. Now that I am running a fan, the engine sits too far forward putting the fan too deep into the shroud. I’m running a 4 core radiator. The current stands are in the two forward holes on the frame. The driver’s side stand was definitely cut for the bb headers. From several threads, it seems that the stands are in the correct position.
I’d like to push the engine and transmission back to gain this needed inches. It seems that if it was sitting on the inline 6 stands, the 2 1/2 inches on the rear bolt holes of the frame would put the fan in the position I am needing. Current setup: 350 w/ serpentine belt drive, 4 core radiator My question is... Do the big block stands sit the 350 more forward than it should be? Needs a little love under the hood. Just getting everything correct (mechanics and wiring) before it goes off to body and paint.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
12-30-2018, 09:20 PM | #2 |
The Older Generation
Re: Engine Stands
I'm not sure about the engine being farther forward with the BB stands without going out and checking but here is a thread I posted a couple of years ago that shows the differences in all of the brackets. http://67-72chevytrucks.com/vboard/s...d.php?t=732393 I can tell you that the BB shroud is different than the SB. Read through this thread..... http://67-72chevytrucks.com/vboard/s...d.php?t=429475 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-30-2018 at 09:26 PM. |
12-30-2018, 09:41 PM | #3 |
Re: Engine Stands
You have small block stands in the correct small block location.
Your fan problem is from the long water pump and accessories on your engine. The chassis and fan shroud was designed for short water pump. That serpentine belt setup looks like it sits further forward on the engine than regular long water pump stuff too. |
12-30-2018, 09:54 PM | #4 | |
Re: Engine Stands
All of this ^^^... Those are hacked up small block stands, but If you put in big block stands, the engine will be pushed back about 1-1/2''. Then you can use a big block shroud and everything will fit perfect. BUT this requires moving the trans back also and having the drive shaft and the exhaust redone amongst a few misc items relocated, shortened or stretched. OR, just install a big block shroud and see where the blade sits |
12-30-2018, 09:58 PM | #5 |
Re: Engine Stands
Thanks for the replies. LockDoc, I actually had read your post before posting a thread. The shroud is a SB non AC 2wd shroud, I ordered it myself but didn’t use it with my old electric fan setup.
All in all, looks like I’ll be looking for a set of inline 6 perch’s or a set of tubulars.
12-30-2018, 10:03 PM | #6 | |
Re: Engine Stands
12-31-2018, 07:17 PM | #7 | |
Re: Engine Stands
Right now with the depth of your fan it could actually be cavitating some of the air flow instead of a clean draw through (if that makes sense) |
12-31-2018, 07:34 PM | #8 |
Re: Engine Stands
pic
