12-31-2018, 05:17 PM | #1 |
Running rough
So my truck is running a bit rough. I have had the fuel mix screw all the way in and took it out a turn and a quarter until I had it running somewhat ok. But now it won't run unlessitsat half or three quarter choke. Could this be a timing issue or am I just doing something wrong with the set screw
12-31-2018, 05:36 PM | #2 |
Re: Running rough
Sounds like a carb. problem. It could be a bad vacuum leak or water in the fuel. What engine is in it?
George |
12-31-2018, 08:08 PM | #3 |
Re: Running rough
I recently fixed rough runner with a new carb gasket. Just something to check, it had me mystified for a while.
01-01-2019, 02:50 AM | #4 |
Re: Running rough
It's a 250, I need to redo the exhaust on it and the gas in it is fresh. Just rebuilt the carb before gas was put through it. Could it be that it's getting too much air from the exhaust leak at the manifold?
01-01-2019, 01:49 PM | #5 |
Re: Running rough
I don't believe an exhaust leak is going to cause a problem with maintaining an idle, though it is something you'll need to work on eventually. If you need a lot of choke applied to keep it running I would look for a vacuum leak of some kind. Broken vacuum hoses, carb gasket, brake booster etc. Something is letting too much air in and foiling the carburetor mix.
01-01-2019, 02:00 PM | #6 |
Re: Running rough
Yep, getting to much air from somewhere. Try spraying a little something on areas to make it rev if it's coming in.
01-01-2019, 02:08 PM | #7 |
Re: Running rough
If the choke improves and richening up the mixture improves it, you've got a vacuum leak somewhere methinks!
Check hoses, base gaskets, etc... sure sounds like it though. When you say you just "rebuild the carb", isn't that kind of the smoking gun?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-01-2019, 02:50 PM | #8 |
Re: Running rough
How is the ignition system? Plugs, wires, cap rotor.
Points and condensor (if so equipped) Are you 100% positive that there are no vacuum leaks? I bring this up because you can't twist the screws on the carb and rectify these problems. Most "carburetor problems" are actually ignition problems. I'm not suggesting that you don't have a carburetor problem, just pointing out that you should NEVER try to adjust the carb without looking at ignition and vacuum systems FIRST. |
01-01-2019, 02:59 PM | #9 |
Re: Running rough
The exhaust gasket and intake gasket are a one piece item, usually.
If the exhaust manifold-to-head gasket is leaking it should be a no-brainer for you to see that the intake portion of the gasket is also leaking.
'67 GMC 2500, 292, 4spd, AC |
01-01-2019, 03:33 PM | #10 |
Re: Running rough
I take it is a Monojet carb. You may have the float level too low. Or the gasket between the throttle body & fuel bowl is the wrong one or in backwards.
George |
01-01-2019, 11:20 PM | #11 |
Re: Running rough
Do all your ignition diagnosis first. A free DVOM from harbor freight with the correct specs can save you a ton of money and aggravation.
