07-28-2020, 03:11 PM | #26 | |
Re: change my own windshield?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-28-2020, 03:33 PM | #27 |
Agreed. I think Cory’s guy sounds like someone I would try out. The fact that he has a ratio worked out (7:1) speaks volumes about his experience.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
07-28-2020, 04:53 PM | #28 |
just had a local glass guy come put mine in, i suppied the rubber and the trim, he suppied the glass... done deal 200 bucks. the glass was going to cost me more than that.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
07-28-2020, 05:17 PM | #29 |
This may help someone who is searching in their area for a glass company that knows older cars. I didn't have any luck calling actual glass companies, but I called a couple of shops that work on high end classic car builds and ended up getting three recommendations in the area.
08-03-2020, 01:24 PM | #30 |
Still Green but learning
So mixed results. On the way home the bands from the tropical storm started coming in and we had some leakage around the bottom corners. Looks like the seal is a little raised on those, I called them and as expected they said they would correct it.
The other thing is unbeknownst to us the glass guy ordered the glass with the smoke tint across the top. I think it looks good, my son originally said GREAT! I was going to put a a tint across that anyway. Then after the leaking he now is concerned with the bench height it will be an issue. What are your thoughts on that? Smoke or no smoke? I havent driven it but I like the look of it from the outside.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
08-03-2020, 01:50 PM | #31 | |
The Older Generation
All of the windshields I have purchased and installed in my trucks have been tinted and shaded. Personally, I like them, and they help when driving into the sun. I think you would have to be really tall for the shaded area to be a problem, if that is what you are talking about. Just my 2¢ worth.... LockDoc
08-03-2020, 02:44 PM | #32 | |
08-04-2020, 03:25 PM | #33 |
$100 each installed in a 71 Blazer and a 70 GMC by my local Safelite - I provided the Precision gasket for both windows, which was better than the one they were going to use - they provided the glass/labor. My insurance covers a portion of cracked windshields and has an arrangement with Safelite.
2 guys did it. The new guy called the older gey after he checked it out and said he wanted to help. It didn't matter to me if the price was the same. It took them 3 hours to do both trucks in my driveway. I watched the videos online and then found out the price for one installed was only $100 - I didn't think twice about making the call for a pro to do it. No trim in either truck seal though - which seems to play a part in the difficulty. |
08-04-2020, 05:04 PM | #34 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
That leak is common and in many cases is actually not the windshield gasket but the splice in the rain gutter at the top corners of the windshield. The water runs down the A-pillar and pools on the inside below the gasket. Another cause for leaks on a fresh install is bent weld beads (the sharp pinch joint) that locates the gasket. If them things are rusty and bent it makes the new install difficult and can leak. I clean and paint the pinch welds and bend them back straight before installing the glass. Before doing a windshield I always inspect that rain gutter and wont install the glass until the old sealant is removed and the gutter thoroughly wire brushed clean. then the two part self leveling seam sealer applied so no water can enter through that splice. Lots of windshields got blamed for leaks that were rain gutter leaks found after the new glass was installed...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
