Old 05-15-2019, 09:35 PM   #1
ford35lh
Engine ID
I have a 54' 3800 .
How can I tell which engine is in it ???
What gear ratios were available in 54 ???
ch
ford35lh is offline   Reply With Quote
Old 05-15-2019, 09:48 PM   #2
dsraven
Re: Engine ID
you may be able to get that info from the GMheritage center. check online for the contact info. they are pretty good about getting back to you as well. they will need the vin.
the engine should have a number on it but posting a pic would also help.
you could also try here, their manuals are a little spotty on some stuff but they do have specs like that for a lot of stuff.
http://chevy.oldcarmanualproject.com...esto/index.htm
Old 05-16-2019, 05:03 AM   #3
1project2many
Re: Engine ID
Welcome to the forum.
The manuals at the Heritage Center are available online. https://www.gmheritagecenter.com/gm-...tion-kits.html
That shows the options that were available when the truck was built. GM in the states wasn't great about keeping records for the old vehicles though. And over time people love swapping engines, transmissions, and axles so you should plan on doing detective work to learn what is actually installed in your truck.
Do you have any pictures of the truck? If you plan to do a significant amount of work to it you might want to start a "build thread" to share your progress.
1project2many is offline   Reply With Quote
Old 05-16-2019, 10:52 PM   #4
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Re: Engine ID
Head over to Deves website and check it out. Or buy his book, tons of valuable info.
http://devestechnet.com/Home/CastingNumbers
GreasyLikeaBurger is offline   Reply With Quote
Old 05-16-2019, 11:23 PM   #5
mr48chev
mr48chev's Avatar
Re: Engine ID
By checking the engine serial number against this you can see if it is the stock engine that came with the truck pretty easily. http://chevy.oldcarmanualproject.com/models/engine.htm
Note: the engine serial number will not match the number stamped on the door post tag. That didn't come about until 1972 in most cases when the feds wanted more vehicle Id numbers on major parts of the vehicles. http://www.nastyz28.com/decode.php
My ongoing truck projects:
mr48chev is online now   Reply With Quote
