05-25-2019, 09:50 PM | #1 |
At the body shop.
ORD steering brace
NOS manual box on added an ORD box brace.
Strange enough the frame wasnt already broken.
" That didnt make it any newer " " Dont antique the equipment " |
05-25-2019, 09:56 PM | #2 |
Re: ORD steering brace
every one of my trucks gets a ord brace kit .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-26-2019, 12:26 AM | #3 |
At the body shop.
Test drove it after changing the oil.
No more death wobble. 🙃
05-26-2019, 10:57 AM | #4 |
How do you overpower the steering box on a 2 wheel drive truck? I have seen C10's take ridiculous abuse and never cracked a frame around the steering box. I can see putting them on 4WD's but I don't get the 2WD's.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-26-2019, 11:18 AM | #5 |
85 2wd of mine was broken when i purchased the roller truck to build up . i had to weld it up and use the plate kit to fix it . even had a crack in the lower rail lip at the first of 3 bolts that holds the crossmember to the frame .
05-26-2019, 12:16 PM | #6 |
At the body shop.
My 77 was broke
Brothers 78 was Our 68 is broke Was really surprised my 73 wasn't
05-26-2019, 12:39 PM | #7 |
At the body shop.
Broke nearly off at the front crossmember on the 78
05-28-2019, 12:44 PM | #8 |
I have been thinking about doing this on mine as a precaution. How is the fit and finish?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-28-2019, 01:42 PM | #9 |
At the body shop.
Nicest aftermarket stuff I've installed recently.
Needed a spacer between it and the factory crossmember. Tightened up the steering considerably, but changed the box the pitman arm and added the brace in one shot.
05-28-2019, 10:17 PM | #10 |
the ones i have installed just the bolt in brace kit and nothing else ..... they are much more firm in the feedback not as spongey . taking out the frame flex in this area does a lot .
