Old 12-03-2020, 12:20 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
Factory 72 Big block engine and parts
1972 396/402 engine (longblock minus intake) with 41,000 miles. Had stuck lifter so assume you'll need to rebuild. 500 or 700 with intake and valve covers/wire loom pieces
1972 Th400 transmission with 41,000 miles. Unknown condition. Includes torque converter. 250
PS Pump with all brackets and bolts/washers/nuts 220
Alternator brackets with all bolts/washers/nuts 120
BB pulleys 150 (A/C and smog parts gone but all else there)
Air cleaner with spark arrestor and factory wingnut 120
Original radiator to fix or recore (LEAKING) $20
BB Flywheel 40 if not sold with trans
BB factory valve covers (have dents) with Wire loom pieces 50
BB Factory correct date intake with choke and water neck 100
BB wiring harness still flexible and complete 100
Everything for 1,200 (1,870 separately)
Old 12-04-2020, 10:31 AM   #2
Tim Christian
Tim Christian's Avatar
Re: Factory 72 Big block engine and parts
I would like to buy the trans and flywheel as we discussed a while back. Thanks
Tim Christian is offline   Reply With Quote
Old 12-06-2020, 05:17 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
It's yours, sorry, i replied to the old thread a couple times. When would you like to come get it?
Old 12-16-2020, 11:11 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
ttt
