70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Does Anyone Know?
I'm looking for another 85/91 Burb and seem to be finding a lot of them with front bench seats and I want the buckets & console. Does anyone know if the mounting holes for the buckets and console are in the floor even if the Burb originally came with a bench. I'm thinking when they stamp out the floor pan it'd be cheaper for the factory to stamp 2 extra holes in the pan so they could use the same floor pan for the buckets or console instead of inventoring 2 different pans. I've had few Burbs and wanted to crawl under one and look for that but never have.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#2 | |
Re: Does Anyone Know?
Hmmm....
I've had one of each, but never checked to see if the buckets & console were a direct fit into the Burb with a bench... I believe, though, that the console has brackets welded to the floor for mounting, that the bench seat truck wouldn't have. (I could be wrong ![]() So, my suggestion would be...get your drill handy... ![]()
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King |
#4 | |
I just went out and did a quick look-see of the two 2wd Suburbans (with the benchseat) I have in my driveway. One is a 454 rig and the other is a diesel, neither had the bracket for bucket seats that my 85 Suburban has. For the bucket seats, there is a mount welded to the floor, it is for the right front on the driver side and left front on the passenger side of the seats. The only difference is my 85 is a 4x4 diesel so maybe the brackets are there because of the high-hump floor. Couldn't tell if the floors had any markings for the center console. IIRC the center console just bolted to the floor. Hope this helps.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 Last edited by rcbildr; 03-12-2007 at 02:48 AM. |
I am not %100 sure on this as I have not looked at the '88 2wd I am helping to part out since last Wed., but I believe it is similar to a regular cab with buckets; the brackets for the insides of the seat are welded in.
I was going to ask the question of whether the brackets are in fact the same from a truck to a Suburban? The seats and console were gone when I got to it so I didn't really pay that close attention.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If it came with a bench, the bucket brackets won't be there. They are welded in for those with that option. They are in fact the same as a pickup.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Thanks for all the replies guys. Captkaos you told me exactly what I needed to know. Now I'll make sure I find a Burb with the buckets already in it from the factory.
