Old 05-26-2020, 10:31 PM   #1
EricU
63 hub cap question??
Finally getting around to my ’63 Burb Build which will be a full on restoration effort minus the GSI front, DEG rear suspensions with bags at all four corners. And of course the Caddy 472 engine might not be as original as the existing straight six…but anyways,
While getting the new 17” rims ready for paint and installing the hub cap clips I kind of need to figure out what I am going to be doing with my hubcaps.
What I had thought were steel hubcaps with chrome are something else as a magnet doesn’t stick to them.
• Are these hub caps Stainless, Aluminum?
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 05-26-2020, 10:45 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: 63 hub cap question??
They are chrome over brass. http://67-72chevytrucks.com/vboard/s...d.php?t=702839
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 05-26-2020, 11:19 PM   #3
EricU
Originally Posted by cwcarpenter98 View Post
Chrome over brass??? That would explain it, as they definitely look like old chrome. But I wouldn't have guessed over brass
I was looking for that thread but kept going down other post's rabbit holes! Though I didn't see where he mentioned the hubcap composition.
Thank you for the answer!
I guess that I will get out my hammer and dollies and get to work. I have some other items that need to be re-chromed.
Old 05-27-2020, 12:19 AM   #4
oem4me
Be sure the caps you have or acquire are the type made for clips. These will have the extra ring on the backside to accept the clip.
Old 05-27-2020, 05:02 PM   #5
EricU
The factory rims have the nubs which of course my new rims don't have.
That is why I added the clips, took a couple of tries but got them located so that the hub caps can go on and stay on.
Before I spend any time with a hammer and dolly, then have them rechromed, I do want to give them a road test!
Old 05-27-2020, 08:48 PM   #6
factorystock
factorystock's Avatar
Chrome over brass??? Though I didn't see where he mentioned the hubcap composition.
The subject is covered more in depth in another thread. http://67-72chevytrucks.com/vboard/s...rome+hubcapsGM pickups used this weak hubcap construction till around '72-'73 till aluminum was used
factorystock is offline   Reply With Quote
Old 05-27-2020, 09:46 PM   #7
oem4me
Good luck with that. The caps shown are the type that fit over nubs, not clips.
I guess if you can make them work, then whatever, right?
Old 05-27-2020, 09:49 PM   #8
Asshat
Asshat's Avatar
Can you show how you did the clips?
Asshat is offline   Reply With Quote
Old 05-27-2020, 10:04 PM   #9
cwcarpenter98
I'm not sure who makes them, but there are clips made specifically to attach nub style hubcaps to wheels such as 22" transport wheels that never came with clips or even hubcaps from the factory. Lots of guys have done it that way recently, but I have heard of the slips not being adjusted tight enough and the cap comes flying off while cruising
Christian Carpenter
Old 05-27-2020, 11:46 PM   #10
EricU
I'll post a pic when I get my rims back from the sandblaster so I can paint them this weekend.
I just drilled and bolted the clips on the wheel. Pretty simple.
