Old 06-05-2011, 11:58 PM   #1
Mikec10
Mikec10's Avatar
Lsx swap ecu/harness
i've always wanted to do a lsx swap into my 80 c10, but the ecu and wiring harness intimidate me a lot. Is it really hard to figure out or what? im new to fuel injection lol
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 06-06-2011, 03:07 AM   #2
5150.4.67
Re: Lsx swap ecu/harness
It's not the worst thing you will tackle, but it does take time to research it and learn.
Don't want or have the time to spend? No prob. Plenty of companies making swap harnesses these days. But their time will cost you. A decent harness is about $600-700.
You can do it!
Check out http://www.lt1swap.com/
5150.4.67 is offline   Reply With Quote
Old 06-06-2011, 10:25 AM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
You can do it!
What he said, take your time, reaserch the wiring diagram for your engine as there are some differences that are not covered by the LT1swap site. It can be done, I have about $40 in my harness.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-06-2011, 10:54 AM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Or go the less popular route...with a carb
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-06-2011, 11:11 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
re-wiring the actual body of the truck (COMPLETE re-wire, not even stock fuse panel) from scratch is/was much worse. The actual engine wiring isn't that bad, provided you can get a good wiring diagram and can use a multi meter just incase.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-07-2011, 09:37 AM   #6
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
any regrets? I'm thinking of going the same route...
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 06-07-2011, 01:22 PM   #7
68GMCCustom
not me! It all depends on what you want from your ride. if you like to tinker with it and its not a daily driver then a carb works.
For a daily driver....a hands off-start every time-no fuss-better mpg- efi system might be in order...
My truck isn't totally tech deprived tho. An MSD box controls the timing using the crank/cam sensors instead of a distributor, a MAP sensor helps adjust timing for fuel economy (not hooked up yet), and I monitor the air/fuel ratios with two wide-band a/f gauges.
If my truck doesn't start on the 1st hit, it does on the 2nd...... and I can live with that.
Kurt -
Old 06-07-2011, 04:20 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If your buying a complete motor, it just seems backwards to me to take all of the EFI stuff off, to convert to carb just to get around some wiring. Besides you also have the additional costs of the carb-specific parts.
I think some people get scared off by the wiring, and end up spending more time and money on a carb setup...just because they are trying to avoid the wires.
Old 06-07-2011, 05:54 PM   #9
68GMCCustom
In my case....my brand new motor came with the intake, fuel rails, injectors, and sensors...but no harness, and no ecm. I sold my efi stuff for enough to pay for the new GMPP intake. I guess some people just don't get wanting to "blend" the old look and technology with the new. I do. I also agree a carb isn't for everybody or every situation.....tho neither is efi.
as for me.....I think a carb'd LSx is cool!
Kurt -
