09-03-2014, 12:34 AM | #26 |
Re: 327 fan setup
ive seen this style also and the uber rare modulated one thats in the chevy books for AC V8, a guy on ebay wanted $600 last yr i have a pic somewhere only ever seen one, every and it was from a vette
09-03-2014, 02:02 AM | #27 | |
Re: 327 fan setup
http://67-72chevytrucks.com/vboard/s...d.php?t=531177 I will do my best to copy it though! |
09-03-2014, 04:37 PM | #28 |
Re: 327 fan setup
That makes me sick to my stomach, did you see the photo of the fan on my truck the exact one you show in your photo, I through it away because I didn't want it at that time and was going with electric fans.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ Last edited by Budman56; 09-03-2014 at 10:58 PM. |
09-03-2014, 04:43 PM | #29 |
Re: 327 fan setup
Don't feel to bad Budman, its the Style of clutch that's so rare and a slightly different fan blade that made that combination Pimpston posted DIFFERENT than yours and so valuable. You did through away about $50.00 , not 600.00
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
09-03-2014, 06:53 PM | #30 |
Re: 327 fan setup
Just because, he wanted 600 bucks doesn't mean he got it or that it's worth it.
09-03-2014, 07:04 PM | #31 |
Re: 327 fan setup
Very true but I've seen just the clutches used for that price. Just a select few that would spend for that piece, not something I need luckily
09-03-2014, 07:31 PM | #32 |
Re: 327 fan setup
Yeah, for some lucky guys, their 600 bucks only feels like my 60 bucks....I just put a vintage air on my truck and I currently run a stainless steel 26" flex fan with 6 blades. Now I wonder if perhaps I would've been better off with a thermo-clutch. I went with the flex fan because it looks very similar to the factory fans on Caddies from the 70's. I figured if it works on a 472 or a 500 big block it should be overkill for a 283 with air.
09-03-2014, 07:59 PM | #33 |
Re: 327 fan setup
The blade
09-03-2014, 11:02 PM | #34 |
Re: 327 fan setup
they look the same to me both have 5 blades both were flex fans and both had the same clutch. am I wrong?
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
09-04-2014, 12:18 AM | #35 |
Re: 327 fan setup
the $600 clutch is for a 64 vette they only made a few, the deal is it has a selectable modulator on it, guess it make the clutch "active". i saw the same one in the 60's truck parts book 283 V8 with AC is what it calls for next to the bumper guards, i finally found one on ebay and offered $400 and the guy said its worth more, i gave him a piece of my mind about it being worthless if no one buys it, once it didnt sale i never saw it again... so they do exisit, just at what cost??? i got mine from a member on the 67-72 forum for less then a C-note,blades and all(painted) so im good...
09-04-2014, 02:39 AM | #36 |
Re: 327 fan setup
Ok, I am overloaded now... I asked what time is it, and you explained how to build a watch! But it is all good info - thanks!!! So if you were me, would you track down these two parts for the fan and clutch as posted by Yelmer, or go with that 7-bladed beast? Really appreciate all the help! --Rob
66 Custom Camper 327 AC PS PB 66 C20 292 76 C25 Sierra Classic 76 C25 Sierra Grande 76 Camper Special 77 Sierra Grande 02 Suburban - the DD |
09-04-2014, 09:23 AM | #37 |
Re: 327 fan setup
Quote "I'm trying to take the setup back to the way it came from the factory. thanks - Rob "
This was your original statement that prompted the guys who like learning about original to chime in. I know I learned some things as I did a couple hours research on this fan blade. Try this guy for a great deal . http://67-72chevytrucks.com/vboard/s...ght=clutch+fan
09-04-2014, 10:19 AM | #38 | |
Re: 327 fan setup
