04-17-2017, 09:39 AM | #1 |
New Horns
The horn on my truck is dead, I understand that this is a common problem with these trucks. Is there anyone who rebuilds them or is it just easier to by new after market? My truck has only one, but thinking about installing a low note and high note both. Would there be an advantage to this or is it better to just install the one low note?
04-17-2017, 11:54 AM | #2 |
20' Daredevil (Ret)
Re: New Horns
First make sure they are dead..... is the green wire receiving 12vdc when the horn button is pressed? If so, the horn is dead, but they can sometimes be revived by spraying WD-40 inside and letting it soak.
Many people get junkyard horns. I prefer two (high/low) to just one. Or you can look for triples (or more), probably from a Cadillac or other large GM vehicle.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-17-2017, 12:09 PM | #3 |
Re: New Horns
Hi Lo sounds a lot better than a single horn, but I'd recommend what I did: find a four-note Cadillac in a junkyard (or eBay) and harvest that setup.
Sounds like a train because it has the full chord. Not as loud as a train, of course, but still 4 horns loud.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
04-17-2017, 01:59 PM | #4 |
Re: New Horns
The Delco dual tone horn kits are being re-popped now. $90 for the set if you got the cheddar.
04-17-2017, 07:06 PM | #5 |
Re: New Horns
Im using one from a late model chevy pickup. I cut off the original mounting bracket and welded onto the new horn mount. works fine. 5.00 investment from u-pullit junkyard.
04-17-2017, 07:07 PM | #6 |
Re: New Horns
$88 for the four-note set on eBay. Well, it was until I grabbed it since I liked my first set so much... but there will be others.
04-17-2017, 07:42 PM | #7 |
Re: New Horns
I just mounted a 70s/80s Mercedes horn in my '68 C/10. Sounds funny, but it works until I can find some 'period correct' horns. OEM horn burned out after only 49 years -- must've been built on a Friday during hunting season.
04-18-2017, 12:41 AM | #8 |
Re: New Horns
I like the old VW horn "beep beep"
04-18-2017, 02:06 AM | #9 |
Re: New Horns
04-18-2017, 08:29 AM | #10 |
Re: New Horns
Thanks guys for the advice. Mine is dead, even pulled it off, grounded it on the battery and ran a wire from the positive post to it. I like the idea of the 4 note from the old Cadillac. I guess it's about time for me to visit our local U pull it yard. I'm also going to look for a front stabilizer bar while I'm there.
