Old 03-14-2018, 07:27 AM   #951
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 C10 SWB - Big Block project
Originally Posted by NoNeck View Post
What do you guys think of "7 Year Itch" for the name of Chad's truck? We started on it almost 7 years to the day that it was finished!
POP
The truck looks great!
Cool name too
Old 03-14-2018, 08:44 AM   #952
Bennett68C10
Bennett68C10's Avatar
Truck is beautiful and I like the name as well!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-14-2018, 11:06 AM   #953
FRCvette
I like the name too.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 03-19-2018, 01:14 PM   #954
CC69Rat
CC69Rat's Avatar
Just checking in, Pop and I have been working through a bit of a problem with the 68. 2-3 miles on a test drive and all 4 rotors were smoking they were so hot. Bad brake smell, etc. It wasn't a pretty sight. The truck felt like it was loading up on timing, cracking and popping a bit (more on this in a sec) and wouldn't shift to third. It was turning 4k+ rpm going maybe 20mph.
We found we had the clevis and pin on the pedal a little too far out. Pop dropped the steering column back down and we adjusted the pin. When you let your foot all the way off the brake it should have 1/2 or so "pull off" so it pulls the push rod off the MC. Ours was holding pressure (quite a bit actually) on the pedal. Basically we were driving with our foot on the brakes.
When we adjusted it back off, man the truck is like night and day difference. It will idle and just slow roll in gear doing that nasty choppy idle. It sounds really good. It's a different truck without the brakes on.
We have an HEI in this truck. What are your thoughts on running both mechanical and vacuum advance? Should we block one, maybe go to an MSD, etc? The cam is pretty big. It's the 60203 (I think?) Voodoo cam. Would you swap the distributor? On idle it's nice.. slow acceleration it's nice but it concerns me at the 4k rpm range it seems to have been breaking up a little. Was that just because it was working extra hard with the brakes on?
Something else to consider I have 2.5" tailpipe. The mufflers are Magnaflow, 4" x 14" long tube type. They're not very big at all. Could the cracking be coming from too much back pressure? Are the mufflers really big enough for the motor? Dad and I are swapping them out for some bigger ovals I guess we'll see. I just wanted to get some input on it.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-19-2018, 06:21 PM   #955
68Gold/white
Unless you have a strip only vehicle, you can benefit from vacuum advance, better mileage is not something I would give up. You do NOT have to use vacuum advance, though....
What power valve is in that thing, jets? Total timing. An HEI will work OK, till about 6200, but could use some massaging sometimes.
Tell us about your fuel system, line size, pump, all the way to the tank.........
68Gold/white is offline   Reply With Quote
Old 03-26-2018, 02:33 PM   #956
NoNeck
NoNeck's Avatar
The carb is a Holley 3310 with 750 cfm. It has been blueprinted for the engine and uses 73 Jets. The Power Valve is 4.5" with a blow out preventer ball added.
The truck uses a '69 Camaro tank mounted in the rear with 3/8" metal fuel lines throughout. A fuel pressure regulator is also used and is set at 5.5 psi. The fuel pump is a mechanical AC Delco.
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 03-26-2018, 02:38 PM   #957
NoNeck
NoNeck's Avatar
We got a 4 wheel alignment on the truck today. It drives much nicer now.
POP
Old 03-26-2018, 03:13 PM   #958
68Gold/white
Do you have any verification the the 5.5 psi is holding at the carb?
Old 03-28-2018, 01:15 AM   #959
diggerbob
diggerbob's Avatar
I just discovered this build thread after spotting your posts on windshield install tips (grrr) and driveline vibration (grrr). My wife kept asking me what I was spending so much time reading about on the laptop tonight. 39 pages makes for a long read, but I enjoyed it thoroughly. Beautiful color, interior and wheel combination BTW-loved the wood bed floor too. Now that your Dad has helped you finish this project, can you send him to West TN to help me sort out a few odds and ends on my 1970?
diggerbob is offline   Reply With Quote
Old 04-13-2018, 07:35 AM   #960
papsoldblue72
papsoldblue72's Avatar
I would like to know how you did the license plate flip down in the back....
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 04-13-2018, 09:50 AM   #961
knomadd
knomadd's Avatar
It's likely an old muscle car license plate bracket. Any car that had the fuel filler behind the license plate would have one.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-13-2018, 01:09 PM   #962
NoNeck
NoNeck's Avatar
We installed an inline gauge to verify the psi and it actually read 5.9. It is now backed down to 5 psi and reads a constant 5.5 psi. Thanks for the suggestion.
Now that your Dad has helped you finish this project, can you send him to West TN...
Diggerbob, Chad's Dad here. I am glad you enjoyed the build on this truck. Now that the truck is almost finished my wife has this "Honey-Do" list a mile long. I imagine I will be busy for the rest of the year! :-)
Old 04-13-2018, 01:43 PM   #963
NoNeck
NoNeck's Avatar
Duane, I opened up the stock license plate bracket to access the filler neck with a metal cut off wheel. Then I located a flip down license plate holder from a 1984 Monte Carlo. After drilling a couple of mounting holes I bolted it up and it works great. Any GM license plate holder from '78-'87 Grand Prixs, Monte Carlos, Buick Skylark, etc. should work.
Old 04-15-2018, 01:20 PM   #964
nlped
nlped's Avatar
Hey guys, Kim & I had a blast hanging out this weekend! Truck looks & sounds AMAZING!!! Looking forward to GoodGuys!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-16-2018, 02:17 PM   #965
NoNeck
NoNeck's Avatar
It was a lot of fun Ed. Sorry I couldn't get to the Coker show, but these old legs just wouldn't cooperate. You guys are welcome anytime! Tell Kim we said hello.
POP
Old 04-26-2018, 07:50 PM   #966
CC69Rat
CC69Rat's Avatar
High Hump! The boot is off a late model Jeep JK manual. I just cut the factory rectangle ring off of it and dyed it tan. It looks lighter in the picture than it is in person. Not sure why, camera flash I guess.
Chad
Old 05-10-2018, 02:52 PM   #967
NoNeck
NoNeck's Avatar
We worked underneath the truck this morning cleaning and detailing it for the Good Guys show on Saturday in Nashville, TN. Tomorrow we plan to shine her up a little and get some miles on the engine to complete the break in.
It will be FOR SALE at the show, so if anyone needs a beautiful one-of-a-kind C10, this is it.
POP
Old 05-12-2018, 03:53 PM   #968
nlped
nlped's Avatar
It’s a beauty!!!
Carter
Old 05-12-2018, 07:43 PM   #969
builtbyKane
builtbyKane's Avatar
Originally Posted by nlped View Post
It’s a beauty!!!
that is a truck I would love to have in my collection.
builtbyKane is offline   Reply With Quote
Old 05-12-2018, 07:48 PM   #970
CC69Rat
CC69Rat's Avatar
It's for sale..
Chad
Old 05-13-2018, 04:11 PM   #971
CC69Rat
CC69Rat's Avatar
It’s a beauty!!!
Thank you my friend.
Chad
Old 05-15-2018, 06:17 PM   #972
NoNeck
NoNeck's Avatar
Another picture of the truck at Good Guys.
POP
Old 05-15-2018, 06:42 PM   #973
lolife99
67-72 parts collector,…
lolife99's Avatar
So VERY nice!
Keith
Convert to disc brakes.
Old 05-17-2018, 06:28 PM   #974
CC69Rat
CC69Rat's Avatar
So VERY nice!
Means a lot coming from you my friend. Thank you.
Chad
Old 05-26-2018, 05:59 PM   #975
NoNeck
NoNeck's Avatar
Chad's truck has been running a little warmer than we like, so we worked today installing high-output dual electric fans with shroud from DeRale Performance.
We purchased the DeRale 16927 Kit from Summit and the construction quality is really nice. The dual 13" fans flow a combined 4,000 CFM which should be plenty for the Big Block. This kit with shroud measures 18" H x 26" W and is 3.550" thick which fits the aluminum radiator perfectly. The fans feature 7 blades with maximum 1,680 fan RPM. Amp Draw is 49.60 amps for both fans.
Dual relay harnesses are included as well as an extra wire for air conditioning over ride.
We had to make a few minor modifications in order to use the factory 4-core radiator hold downs, but I think it turned out pretty nice. Next step is to wire in the relays, fill with fresh antifreeze, a bottle of Redline Water Wetter and pressurize the system. That will have to wait until Monday... it's two hot in the garage for us today.
POP
