01-04-2003, 01:28 AM | #26 |
SLICER AND DICIER
I have the glass, but have not done the install yet. I have a whole room full of parts awaiting install. LOL The grill is a full phantom. I test fit it then stored it with the rest of the parts. Ithink I got a pic.
01 Tahoe 22's 2/4 drop and tv's 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
01-04-2003, 01:34 AM | #27 |
Alright!!! That looks cool. Is that picture with the supercharger and all on there? It only comes up to there? What color is it gonna be? Thanks.
Brandon |
01-04-2003, 01:38 AM | #28 |
drag it like you stole it
i want to know how the hell that copper colored long bed has the stock hood hinges in with the body drop on 20's. there was no way i could have used stock hinges with my twenties. but then again, the truck was in truckin so it could actually have 17's on it. any one else notice that in its feature?
negative camber //LA\\ |
01-04-2003, 01:42 AM | #29 |
Nah, it's rockin 20's. What are you saying about the feature, does it say it has 17's?
Brandon |
01-04-2003, 01:48 AM | #30 |
hell yeah its on 20's
01-04-2003, 01:56 AM | #31 |
L.E.D. Freak
All this talk about 20's but what about tire sizes that work well? I'm thinking a 275/45/20 Tire rack sells Goodyears for 133.00!
Also where is the cheapest place to get 20" wheels? I want to go with a 5 spoke of some sort. Thinking Stealths, or Vistas.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
01-04-2003, 06:58 AM | #33 |
THIS ONE IS MINE. IT SITS WITH A 4-6 DROP 20X8 W/275/45 FRONT
20X9.5 W/285/50 REAR. I'LL TRY AND GET SOME BETTER PIC'S THIS WEEKEND. GOT A DIG. CAMERA FOR MY GIRLFRIEND FOR X-MAS |
01-04-2003, 06:59 AM | #34 |
SIDE SHOT
01-04-2003, 11:23 AM | #35 |
So Many Ideas, So Little Money
yeah, that truck is 20s up front, youcan tell, and I was thinking the bac was 22s
Nsane. everytime I see ur truck I think about coming down there ad "borrowign" the truck andall ur pars :-) you wouldn't mind would you?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
01-04-2003, 12:05 PM | #36 |
Here is mine.
01-04-2003, 01:37 PM | #37 |
could someone please tell me the color on the firt truck the light blue one?!?!
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!! |
01-04-2003, 02:58 PM | #38 |
L.E.D. Freak
GREEN70-72 you say you have 275/45/20s upfront. Do you have any clearance issues?
brad2 what size tires you running? Man I love that blazer! Does it have bags?
01-04-2003, 04:25 PM | #39 |
brad, that blazer/jimmy is badazz......what wheel-tire combo is that?
01-04-2003, 04:46 PM | #40 |
REUMSTER: AT FIRST MY RIGHT FRONT TIRE WOULD SCRUB THE FENDERWELL JUST A BIT WHEN I MADE A LEFT HAND TURN ON A BUMP.MY SUSPISIONS(SP?) WERE THAT IT WAS A SWAY BAR ISSUE(BUSHINGS) WELL I GOT RID OF THE 1.0625" WENT TO A 1.25" WITH POLY BUSHINGS (DONE LAST WEEKEND) AND HAVE YET TO HAVE THE TIRE HIT. TO NOTE MY OLD BUSHINGS WERE SHOT.
01-04-2003, 06:52 PM | #41 |
I am running a 245/40/20 on a 20x8.5 in the front and 295/40/20 and 20x10 on back. The wheels are torque thrust II's. Yes it is bagged in that picture and could have been lower if I had let some air out.
01-04-2003, 07:03 PM | #42 |
L.E.D. Freak
brad2 you still have it don't you? Or do I remember you getting rid of it? Do you have pictures of the tanks/valves etc... where they're mounted?
01-04-2003, 07:03 PM | #43 |
L.E.D. Freak
01-04-2003, 07:36 PM | #44 |
I still have it but it looks nothing like that now. There will be more on that later. I don't have any pics of the valves or tank.....sorry. There is very little room under ours as I am sure you are aware. I mounted a 3 gallon tank inside just behind the rear passenger wheelwell. I mounted the compressor and valves right below the tank on the frame. It would be best to fab up a shield of some sort because they catch all the spray comeing off the back tire.
01-04-2003, 10:44 PM | #45 |
i'm runnin 20x9 all the way around with 255/35/20 Nitto 555
01-05-2003, 12:08 AM | #46 |
Progress = 0%
Just for a comparison...... here are my 18's......
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
01-05-2003, 01:06 AM | #47 |
PROJECT 7DEUCE
Theres some bad a$$$ trucks in this post,but i got a ? for those with bags in the rear how much of a notch did you cut and did you have to cut up the bed like the copper 72 in truckin last month...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-05-2003, 02:59 AM | #48 |
brad2, I'm diggin' the blazer.
01-05-2003, 03:09 AM | #49 |
L.E.D. Freak
lotik you have pictures? I just thought that 275/45/20s would give a good overall ride for 20s seeing as they are 28.9" tall cheap, and will give you a side wall of 5" that will ride ok, and still corner awsome.
FRENCHBLUE72 Most of the guys here only have a bolt on Early Classic C-notch thats very popular. I need to get one. And if you go with bags it's allmost a need modification. So the truck isn't racked when aired out.
01-05-2003, 03:19 AM | #50 |
Low & Slow
Nsane I have to give you props for the SS on the fenders.
70' C-10 LWB Fleetside 4.5/6 drop |
