Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-28-2020, 11:01 PM   #1
CJ2A
CJ2A's Avatar
Bulb keeps burning out
In my 1995 Chevy the left rear turn indicator light / brake light bulb keeps burning out. I am on bulb # 3, when the first bulb was bad I swapped it out and the #2 bulb that only lasted two days. The #3 bulb is now out and it is day 3 of its life
Any suggestion ?
48 CJ2A
63 1500 GMC (LS1 w/ Muncie 4spd)
68 RS Camaro
71 K20 BBC & granny 4 speed
95 2500 4x4
17 HD2500 4x4
Want => 67 C10 short bed w/ Manual Tranny
CJ2A is offline   Reply With Quote
Old 10-30-2020, 02:53 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Bulb keeps burning out
Take bulb out put you volt meter in the socket on volts and ground it. Turn the lights on see what kind of voltage your getting. Could have a voltage regulator stuck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-30-2020, 10:38 PM   #3
franken
Just a WAG but maybe the contact somewhere is loose and turning the light on and off frequently and making it fail.
franken is offline   Reply With Quote
