08-10-2018, 08:49 AM | #1 |
Brake Booster Question?
So I am taking this booster off a 1957 car. The front disc brakes are on seperate lines. The top and bottom one, coming out of valve in front, control left and right disc. I am putting it on a 1969 truck that I converted to disc brakes. The lines are factory on truck, front line splits. Should I run new and split and plumb like the 57 car or can I used factory and plug a hole on the valve?
Also the bolt pattern at fire wall doesnt match up. Should I cut top studs on truck and drill new ones to fit? |
08-10-2018, 09:25 AM | #2 |
Re: Brake Booster Question?
To use that proportioning valve you want to use all it's ports. Might want to consider something made for a C/10 that bolts on. If you are stuck on using that one then go with how it is designed. On mounting, I imagine you will need to make an adapter plate.
08-10-2018, 12:43 PM | #3 |
The rod on the booster has to line up with the brake pedal. On the 67C10, the hole is low and usually requires a linkage bracket for about $60. I don't know where the older booster rod lines up, but drilling new holes will take advantage of the OEM bolts that have some reinforcement so the bulkhead or firewall doesn't flex. Some brake pedals have a linkage hole higher up, use it if you have one. It helps with mechanical advantage for your foot to booster ratio. LoL.
The original front brake line work off of one feed line into a "Tee", then from there it goes to left & right. You have two lines for the front, so that 3/16" flare fitting will require union with a flare design. You can fabricate a bracket to hold them after you make a decision to go outside the frame or inside the frame. I chose to drill the frame and run a single front line thru a grommet for each side to hide them, but evenly spaced to look clean. Remember to leave enough room for wrenching when you make you run choice. I used a flare union in the middle of the frame and secured each line with wrap around clips bolted to the crossmember for the right and inside the frame for the left. The rear line can follow the fronts in the same fashion, while spaced equally to look good. A flare union is used there also to the rear single line. Hope this helps. Other choice is to plug one of the front lines at the proportioning valve, but use a flare fitting plug to complete a good seal. Then run one line down to OEM "TEE" fitting. I think the front lines on that proportioning valve is 3/16" and rear is 1/4". You have a couple of ways to go, depending on how much room you have to work in. You may have to get a 3/16" to 1/4" flare line adaptor if you use the OEM "TEE" with the lines shown in the photo. Best of luck.
Removed |
08-14-2018, 07:46 AM | #4 | |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-14-2018, 12:55 PM | #5 |
Plug the top line of the combo valve and use the bottom fitting for the existing brake line. i know I had to get adapters to get the truck lines to work with my combo valve.
Get a bigger booster and make sure the bell crank for the booster is correct (as stated above).
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
08-14-2018, 02:25 PM | #6 |
I have this booster so I will try it first, amost identical setup on the 57 as on the 69 truck and it stopped it fine. The brake lines will have to be adapted to fit.
