Old 02-21-2017, 07:37 PM   #26
Johnnyboy55
Re: Making a G20 a 4x4???
Hi there. I am new to the forum so bear with the poor computer skills. This is my 1986 g20 4x4 conversion, did it the hard way[myself] but worth it
Johnnyboy55 is offline   Reply With Quote
Old 08-13-2017, 09:36 PM   #27
Dlatimer
Hi I sure like your van I have one I am about to start on its a 1983 GMC shorty
Dlatimer is offline   Reply With Quote
Old 08-13-2017, 09:39 PM   #28
Dlatimer
Hi thats a good looking van I have a 1983 GMC Shory t110
inch wheel base I am about to start a 4x4 conversion on Any advice would be welcomed
Old 08-14-2017, 06:40 AM   #29
jjzepplin
jjzepplin's Avatar
Hmm. What a great idea! You could order a 4x4 van back in the day. I always wanted one. Should be pretty cheap to build and I think I see leaf springs in the front of some there don't I? They sure look tough. Any feed back on the handling or capabilities of these bad boys?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-14-2017, 09:38 AM   #30
Dlatimer
Yes leaf springs is the way to go Cheap well not so sure how cheap I do have most of the parts already I do have to fab an engine suport
Old 08-14-2017, 07:42 PM   #31
Johnnyboy55
The conversion was not cheap by any means and above average fabricating skills are required. If I would do it again I would use a driver side drop diff and a 88 or newer transfer case as the engines are 4" over on the passenger side. Overall the conversion was a great success and handled very well even on the highway
Old 08-14-2017, 07:46 PM   #32
Johnnyboy55
How do I add pictures?
Old 08-14-2017, 09:16 PM   #33
Dlatimer
Yes I agree driver side drop would be better But I have 2 solid front diff that are both Passenger side drop One is out of an 1988 3/4 ton truck the other is out of a K5 Blazer Not sure of year yet I have to get the tree off of it first Its a little tight to get into yet Tree smashed it Yes the engine support has to be fabed and spring hangers
Old 08-14-2017, 09:21 PM   #34
Dlatimer
The pitchers I am not for sure I just joined this site and dont know how to work this yet I sure would like to get pics of the engine support It would help a lot to see what I am up against If you want you can email them to me its dlatimer55@gmail.com
Old 08-14-2017, 09:44 PM   #35
Dlatimer
I have also heard that the diff can be swapped from passenger to driver side drop It would take a shop to be done right
Old 08-16-2017, 10:32 PM   #36
Dlatimer
Hi from what I have heard they handle good I am hoping all will trun out good I have decideed to swap my 10 bolt front to driver side Use the Trans and Transfer case out of the 1988 3/4 ton pickup And the Neg Sprung front springs out of a K5 Blazer I am wanting to use it as a daily driver
Old 08-16-2017, 11:27 PM   #37
mud.man.rj
mud.man.rj's Avatar
I hope you choose to build it, would be cool and not many around.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 08-16-2017, 11:38 PM   #38
Dlatimer
Yes I am I have stocked piled all most every thing I need I have two donor vans I picked up for a few hundered dollars I also have a K5 Blazer that a tree feel in the middle of it its all in tack just sits a lot lower in the middle now The van I am building is a 1983 GMC Rally but I have Steel Grill from a 76 and I will use the smaller bumpers from 76 and two head light system I am taking all side window out and back doors window out and put all sheet metal in
