04-24-2021, 09:09 PM | #1 |
Pulling engine quo
So lm pulling the old 292 with trans from my 1980 c30. Got everything off and cherry picker on it. Looking at the truck, not sure if I have the lift in the hoist to clear the grill and core support. What's involved in taking these off? Is it worth it. Done engine swaps in my 72 several times and left it in, but this truck sets up higher. Guess I could pull the tires...
04-25-2021, 09:55 AM | #2 |
Sb 400 club
Re: Pulling engine quo
Last one I did I pulled the front clip as a whole unit. Unbolt the frenders at the cab and inner fender bolt, unplug the headlight bulkhead, disconnect the squirter resivour, open the hood half way and attach the ratchet straps. Unbolt the two front rad mounts and disco the trans cooler lines and your out. So much room to work around the engine area and clean up the bay and firewall. Also removing just the rad support is more bolts to undo.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
04-25-2021, 11:24 AM | #3 |
Just pull the grille and everything off it's pretty easy on these trucks.
As 84 400 said it will give you so much more room to work with.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! |
04-25-2021, 12:49 PM | #4 |
If the main goal is getting the 292 out and pulling the tires gives you enough room to to the job, seems the easy and simple answer. Just make sure you still have enough space under the truck to tilt the motor/trans combo to clear things.
04-25-2021, 06:46 PM | #5 |
I have also removed front wheels and dropped them lower on some blocks. It was easier than dealing with the AC/Rad. Trans and stuff.
04-29-2021, 08:14 PM | #6 |
I pull the valve cores out and just let the front tires go flat to get the motor out of my truck.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
04-30-2021, 09:12 AM | #7 |
Been there, done that. Your C-30 should be much easier than my lifted K20 was. I knew mine was too much for my cherry picker so I bought a rolling gantry crane and of course my ceiling height was just a bit too short and the oil pan still rubbed the core support. I didn't pull the core support because I didn't want to deal with the A/C and having to get it recharged.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
