Old 02-17-2019, 12:06 PM   #1
WB72
Before and After
WB72's Avatar
72 parking brake hardware. Pic included
I am looking for this specific piece from the brake hardware. I think I can make it if I knew exactly what it looks like.
Would anyone have one they could take a couple of photos for me. It is the part that goes on to the solid rod through the frame to tension the cable.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 02-17-2019, 01:36 PM   #2
geezer#99
geezer#99's Avatar
Re: 72 parking brake hardware. Pic included
I think this would be it.
http://sokyclassics.com/product.php?...08c534090a1395
It’s the same as #9 in the diagram.
Old 02-17-2019, 07:15 PM   #3
WB72
Before and After
WB72's Avatar
Geezer#99,
It is the same as #9. Although I do not need that item. I’m looking for tha part that goes on the rod, not the brake cable.
66,000 miles.
Alberta, CANADA
Old 02-17-2019, 08:05 PM   #4
Sparky dave
Yes think you will be able to make it as it’s only folded tin it hooks over the cable and is a tight fit so the cable can’t fall out I’ll take a picture of it tomorrow if no one beats me too it
Sparky dave is offline   Reply With Quote
Old 02-17-2019, 08:09 PM   #5
Sparky dave
It’s called a parking brake equaliser apparently here is a pic I found for you on google images
Old 02-18-2019, 12:05 PM   #6
WB72
Before and After
WB72's Avatar
I am looking for the other side. It mounts to the solid rod that has no threads. Just a button end that resembles a rivet.
I’m trying to figure out how it holds the cable when it is loose, and yet stays on t the rod at the same time.
66,000 miles.
Alberta, CANADA
Old 02-18-2019, 12:24 PM   #7
1971_CST_C10
Did you try Scott at Scott's Super Truck's in Penhold Alberta just south of Reddeer ?
Darren
1967 C10 Shortbox
1971 Monte Carlo SS buckets and console #'s car
1970 350 Monte Carlo bench seat
1970 El Camino SS
1971_CST_C10 is offline   Reply With Quote
Old 02-18-2019, 12:49 PM   #8
dfwright
dfwright's Avatar
Here's a pic that shows both of the clips -- The rod goes through the clip, above the cable. The other end of the rod connects to the frame. Note that the clip is curved slightly to allow the cable to move freely
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-18-2019, 05:20 PM   #9
S_Gibson
S_Gibson's Avatar
https://www.rockauto.com/en/moreinfo...029833&jsn=324
Rock Auto has the guides and clips for less than $17.
Stupidity was meant to be painful!
S_Gibson is offline   Reply With Quote
Old 02-21-2019, 12:57 AM   #10
WB72
Before and After
WB72's Avatar
That’s the picture I was looking for. Thank you dfwrigh. For what it was worth, I have ordered the kit from Rock shipping to me in Canada is $19 usd. Should arrive tomorrow.
66,000 miles.
Alberta, CANADA
Old 02-21-2019, 01:00 AM   #11
WB72
Before and After
WB72's Avatar
Darren
Scott does handle them, none in stock at this time. I asked if he had any used as well.
I previously had him send me the cable connectors. He usually has some used items kicking around.
66,000 miles.
Alberta, CANADA
