08-21-2003, 10:53 AM | #1 |
Bench Seat Adjustment Rod Repair
I have a 1970 Chevrolet K10 with a bench seat, and the rod that that ties the two seat track adjusting mechanisms together has come unattached. It seems that the passenger side of the rod has a double 90 degree curve that fits into a hole on the adjustment mechanism but the driver side adjuster has a groove that the rod just sits on top of. Is there some sort of clip that holds the rod onto the seat adjuster groove? Also there are some metal links that are tied to the back of the lower seat frame that are not connected to anything. Do these connect to the center of the rod with a spring or some sort of linkage?
Thanks, -Steve |
08-21-2003, 12:15 PM | #2 |
Hey Steve I will take me camera and get you a picture of it later this evening--check back.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
08-21-2003, 12:19 PM | #3 |
Designated A-hole!
Welcome to the board!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-21-2003, 01:51 PM | #4 |
Here you go. ( guess you can tell I am a "expert" photo taker)
08-21-2003, 01:53 PM | #5 |
#2
08-21-2003, 02:07 PM | #6 |
jhow66,
Thanks for the pictures. Is there any way you can take a picture of the end of the crossover rod that connects to the driver side track latch? (I am talking about the rod that connects the driver side seat track latch to the passenger side seat track latch.) I can't figure out what holds the rod the onto latch mechanism. On the passenger side, there is a hole that the rod slips through, but on the driver side there is a finger or notch that the rod just rests in. It seems that there would be some sort of clip that holds the rod onto the seat track latch. -Steve |
08-21-2003, 03:37 PM | #7 |
Will do --give a couple of hours --just came in from mowing--92* & 68 yrs. young.
08-21-2003, 05:17 PM | #8 |
Sent PM with a couple of pictures
08-21-2003, 05:20 PM | #9 |
pictures
oops sorry forgot you were new--here they are:
08-21-2003, 05:23 PM | #10 |
other one:-- nothing holds it on but the way it is bent--also when you run it through loops it will stay put.
08-21-2003, 10:54 PM | #11 |
jhow66,
Thanks for the pictures. I finally figured out what is missing on my seat. It looks like the spring and the clip and the end of the latch are missing. I didn't quite figure it out from the first set of pictures you posted. Right now I have the rod butted up against the end of the latch mechanism (the "L" shaped part) and there is some wires wrapped around the two. Is there any chance you might know of a place that would sell the spring and the clip? Thanks again for posting the pictures. They were a great help. -Steve |
08-22-2003, 11:09 AM | #12 |
Try junk yard--'73 up should be the same for awhile--Gm does not like to change anything if they don't have to. Good luck.
08-26-2015, 12:03 AM | #13 |
Re: Bench Seat Adjustment Rod Repair
Just the ticket I was looking for.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-29-2021, 11:42 AM | #14 |
08-29-2021, 12:01 PM | #15 |
I fixed mine with a piece of steel cable and crimped a loop on each end and a small turnbuckle to be able to adjust it with. a lot easier than the steel rod.
08-29-2021, 12:47 PM | #16 |
easier than making one or searching the junk yard
https://www.carparts.com/details/Che...2030%20to%2035 |
