Old 09-30-2020, 08:09 AM   #1
Marty68
wheel size specs. 91 with drop spindles
i have an OLD... stalled project. it is a 91 GMC. i put rocker panels and cab corners in it they are finished new fenders ready to install. box patched and painted. drop spindles in the fronr. rear shackles and hangers in the rear.
the stock wheels seem to hit the a frames.
will 80s 15x7 or 8 ralleys solve this?
what inexpensi\ive alternatives are there?
thanks
Marty68 is offline   Reply With Quote
Old 09-30-2020, 12:34 PM   #2
Re: wheel size specs. 91 with drop spindles
The 15x7s might clear. Depending on the drop spindle, the 15x8 may or may not clear. I know it is hit and miss on the pre 88 style trucks and I have heard it is that way on the newer ones also. The older ralleys have less back spacing, so they may clear your a-arms with out mods. Easiest way if you are already looking for new rims is to go 17". Other wise take a grinder and trim/grind the a-arm lip down so it clears the wheels.
Old 09-30-2020, 07:21 PM   #3
Marty68
thats what i was afraid of
Old 10-01-2020, 08:15 AM   #4
Stormin08
Stormin08's Avatar
a arm or knuckle ?
i know of numerous OBS trucks lowered running a 15x7 with no issues.
it will be more dependent on back spacing than anything. Second will be diameter.
the 8" wheel may have the depth to contact the a arm on turns, but what i see more is contact with the tierod mount...
i remember way back, a friend used a lower budget name spindle, bolted on with out issue. i used a belltech, and my toe was way off, as they pulled the tierod mount way in to clear wider wheels.
Stormin08 is offline   Reply With Quote
Old 10-08-2020, 06:19 AM   #5
Marty68
Originally Posted by Stormin08 View Post
a arm or knuckle ?
this project is moving slower than the speed of govt. time will tell.
Old 10-08-2020, 07:01 PM   #6
SCOTI
SCOTI's Avatar
The 'van' ralleys clear drop spindles since it wasn't mentioned.
Van ralleys (15x6.5") front, 8" truck ralleys (15x8 in the rear:
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-12-2020, 07:12 AM   #7
Stormin08
Stormin08's Avatar
good deal, i wouldnt really expect the narrow wheels to have the issues, but rather the wider in a smaller diameter.
Old 10-12-2020, 08:43 AM   #8
SCOTI
SCOTI's Avatar
Correct based on my experiences. Although when I put 18x8"s w/5.25"BS on my 74 C10, I had to trim back the 'rain gutter' for clearance yet the Van Ralleys that were on there didn't require it.
So, even larger diameter wheels might have interference issues depending on back-space/offset.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-13-2020, 07:36 AM   #9
Stormin08
Stormin08's Avatar
i think the overall relation of Dia to BS is the key as the arm flares to the mounting...basically, it hits further up the arm.
