Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 10-11-2020, 10:11 AM   #1
FAKKY
Helping a buddy - dodge AC question
Symptoms were sometimes cold sometimes nothing.
I evacuated system and vaccumed and started recharge to spec (engine on).
BUt low pressure side hit 90 psi and compressor didnt turn on.
I supplied 12v via powerprobe and compressor clutch moves. I checked an replaced fuse - all ok.
I then started looking for low pressure switch - turns out (maybe ?) the dodge 1500 [2004] doesn't have one its only a high pressure switch with some mechansim in the condensor itself for low pressure ?
How do I determine why it appears there is no signal going to compressor to turn on if there is no low pressure switch.
Any help appreciated. I'd like to get back to working on my truck.
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 10-11-2020, 10:56 AM   #2
FAKKY
Re: Helping a buddy - dodge AC question
Another bit of info.
Checked and swapped the relays. All ok.
Checked voltage at the compressor on switch ........ peaks at like 3v. I thought this was a 5V signal but not sure ...... and how that helps. But its not enough to enagage compressor ... 12v from the powerprobe does
Old 10-11-2020, 11:53 AM   #3
Dead Parrot
My 75 C10 doesn't have a low pressure switch. It has a mechanical thermostat with a probe that fits on the cold coils. If the coils get too cold, like frozen up, the switch opens and cycles the compressor off. Possible the Dodge does something similar. If an unrelated repair loosened that connector could explain the intermittent behavior. Or a mouse taste testing a wire or two.
Dead Parrot is offline   Reply With Quote
Old 10-11-2020, 12:37 PM   #4
FAKKY
Yeah the more I read up in it seems like the low side is controlled more by this temp probe in the evap ......
Still not sure why Im seeing a max of 3V at the compressor switch. Heard problems with the TIPM ....... but think its just a bad ac compressor. Still doesnt explain the 3V.
Old 10-11-2020, 12:39 PM   #5
FAKKY
https://www.dieseltruckresource.com/...-273835/page2/
Old 10-13-2020, 09:46 AM   #6
truckdude239
truckdude239's Avatar
check that the condressor fan is running the dodges are bad about the condressor fan dieing and jacking the pressures high and shutting doiwn the compressor
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-14-2020, 08:35 AM   #7
Bigdav160
Bigdav160's Avatar
The compressor is ECM controlled. There should be a pressure transducer on the A/C lines near the compressor. This is NOT a pressure switch but a pressure sensor.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
