Old 07-21-2017, 11:53 AM   #1
ApacheIvan
ApacheIvan's Avatar
466 Dark Olive/White Trucks
I am getting ready to paint my 72 with paint code 466. From what I can tell, this means two tone, 506 Dark Olive and 521 White. Anyone confirm? If you have ever painted your trucks using these colors, what brand is my best bet? Do I need to take a sample to a supplier or will they have what they need?
Would love to see some pictures of your 466 paint code trucks!
Dale - ApacheIvan
1972 Chevy Custom/20 Custom Camper Highlander
http://67-72chevytrucks.com/vboard/s...d.php?t=740479
Original Owner
** Do you have a 1972 Plaid Pickup?**
ApacheIvan is offline   Reply With Quote
Old 07-21-2017, 02:19 PM   #2
jocko
jocko's Avatar
Re: 466 Dark Olive/White Trucks
Just a quick note in case any folks aren't aware - 466 is the deluxe two tone (white middle and top).
Most paint charts have major paint mfgr cross-ref numbers included, but also most paint mfgrs can mix to the GM code (521 is correct for the white, I'd have to check the dark olive).
Personally, I'd go by the GM paint code and not by a sample of your existing paint. Even if original paint, it's faded. If you end up color matching, recommend use an interior surface like the glove box door inside face where the SPID is.
Old 07-21-2017, 02:26 PM   #3
Joesjunk
Joesjunk's Avatar
Here is my original paint dark olive with white top
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 07-21-2017, 02:52 PM   #4
ApacheIvan
ApacheIvan's Avatar
Exactly, Should look something like this:
Dale - ApacheIvan
Original Owner
Old 07-21-2017, 03:04 PM   #5
Joesjunk
Joesjunk's Avatar
Oops sorry I didn't realize you were looking for the 4 tone combo.
Old 07-21-2017, 03:07 PM   #6
ApacheIvan
ApacheIvan's Avatar
Ha, actually It is good to see the right green color, is your original paint? Is that the 506 Olive? I guess what I am looking for is what is the proper color code for the olive, I think I have the only white used, but there were a couple of darker greens and 466 does not really clarify what colors are involved in the two-tone.
Dale - ApacheIvan
Original Owner
Old 07-21-2017, 03:49 PM   #7
Joesjunk
Joesjunk's Avatar
My truck is 100% original paint. It's dark olive metallic. That's the only dark metallic green they offered. They have a dark green that's a solid color also. What does your spid say?
Old 07-21-2017, 03:50 PM   #8
Joesjunk
Joesjunk's Avatar
I just looked at your spid, mine is the color green your truck should be
Old 07-21-2017, 03:54 PM   #9
ApacheIvan
ApacheIvan's Avatar
466 Dk Olive/White
Dale - ApacheIvan
Original Owner
Old 07-21-2017, 04:01 PM   #10
Joesjunk
Joesjunk's Avatar
Here is another picture of my truck, you can really see the green in it
Old 07-21-2017, 05:29 PM   #11
jocko
jocko's Avatar
White (also known as "frost white") - GM RPO 521 = PPG 2185
Dark Olive (also known as "spruce green") = GM RPO 506 = PPG 2207
Deluxe two (4) tone of the two = 466
Conventional (2) two tone of the two = 564 (as shown in Joe's above - same dark olive as yours, just in conv two tone scheme)
DeadheadNM and Sideways have beautiful examples of the deluxe two tone combo also.
Pics #1 and #5 are pretty much exactly your truck Dale, both are avocado plaid highlander Custom Campers.
Old 07-21-2017, 05:39 PM   #12
ApacheIvan
ApacheIvan's Avatar
Pics #1 and #5 are pretty much exactly your truck Dale, both are avocado plaid highlanders Custom Campers.
I should just quit posting and PM Jocko any time I have a question Thank you so much, the 506 is a non-metallic color? There should be no metalflake or anything in the paint right? Whoever painted it last put some flake in it..
Dale - ApacheIvan
Original Owner
Old 07-21-2017, 05:49 PM   #13
jocko
jocko's Avatar
No, I believe 506 is metallic, same paint as on Joe's truck. In other words, don't believe there is a dark olive 72 GM truck color that isn't metallic. You could get that metallic dark olive (also called dark olive poly) in 506 (solid) 564 (conv) and 466 (deluxe). There were other combos also, like my 72, 557, that combined dark olive poly with med olive poly (also known as "willow green"). 557 had the med olive on top (1st pic), 556 had the dark olive on the top (2nd pic). Anyway, all the "olives" were metallic (or poly, same thing, just a different term).
Old 07-21-2017, 07:38 PM   #14
davepl
davepl's Avatar
Here's our old workhorse, a Dark Olive and White GMC 910. Thing is I don't remember it being metallic... 1968.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-21-2017, 08:08 PM   #15
Chevyland
Chevyland's Avatar
As jocko said
In 72 dark olive and med olive were poly/metallic
Dark green. 505 was non metallic
I'm not sure of the code for a two tone truck
Dark green and white
Chevyland is offline   Reply With Quote
Old 07-21-2017, 08:16 PM   #16
jocko
jocko's Avatar
535 and 485 (conventional and deluxe) - 505 also known as "glenwood green"
Old 07-21-2017, 10:29 PM   #17
CG
BlahBlahBlah
Funny, this is the color combo (466) that drew my attention to these trucks just shy of a zillion years ago. Guy I knew was building one, back then I didn't know all the terms, but it was loaded and had the wood grain trim and the wood grain inside. I guess it was a Super.
Such a nice paint combo.
Monroe Swap meet May 18-19.
Mike has the same spots for the NW guys he's had forever.
Lunch time BBQ at the spaces.
If you have stuff to sell bring it along.
If you have a question PM stllookn (Mike) here via the board.
https://67-72chevytrucks.com/vboard/...d.php?t=851291
Old 07-21-2017, 10:36 PM   #18
ApacheIvan
ApacheIvan's Avatar
Mine never had the wood grain on the inside but had the woodgrain trim on the outside.
Dale - ApacheIvan
Original Owner
Old 07-23-2017, 10:55 AM   #19
rharris
rharris's Avatar
72 Super - 466 - Dark olive poly and white. If only it was medium olive poly...........(sigh)
72 Cheyenne Super C10 SWB
2001 Silverado 1500HD Crew
2011 Silverado 2500HD Crew Duramax (Hers)
rharris is offline   Reply With Quote
Old 07-23-2017, 02:33 PM   #20
57taskforce
All about them K’s
57taskforce's Avatar
All of these are excellent examples of dark olive trucks. Mine has the original dark olive paint hiding in a few places. All variants of the olive schemes are some of the best looking colors on these trucks. Hard to beat hugger and white but it's real close. As usual Joes goldmine shows off again haha! Very nice truck!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 04-14-2019, 01:48 PM   #21
Shtudwn
Hi,
Really enjoy this thread.
I have a code: 465 White & Medium Olive for my 1972 K10.
What does the 465 mean as opposed to 466?
Thank you.
Shtudwn is offline   Reply With Quote
Old 04-14-2019, 08:17 PM   #22
jocko
jocko's Avatar
1st pic is 465 (white/medium olive poly in deluxe two tone), 2nd pic is 466 (white/dark olive poly in deluxe two tone)
Old 04-14-2019, 08:29 PM   #23
Shtudwn
I love the "deluxe" white between the two sets of trim except I only have the lower trim.
I think my truck was originally white cab top with the rest medium olive.....but I would sure like a reason to go with the "deluxe" white like I mentioned earlier. I was hoping the code might confirm the actual application.
Old 01-25-2020, 11:59 AM   #24
SRU1436
Here is my 72 with the 466 paint code.
SRU1436 is offline   Reply With Quote
Old 01-25-2020, 12:09 PM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
It’s this one....dark olive poly.
