Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-02-2017, 02:25 PM   #1
GIZZ
GIZZ's Avatar
69 Panel - Project needs a name
I've been on a few forums over the years having different cars. The 1 thing I've never done is a build thread. Today is the day!
Background, I bought this '69 panel way back in 2006. Immediately got 4/6 drop springs, found some new cpp rear arms cheap. I got a 6.0 from a silverado, carb and msd injector controller. I bought a whole running(rusty) '89 burb for the front clip & also the A/C bits.
Then I got divorced. Then I sold the house, I kept the new parts I accumulated but many of the used burb parts ended up at the recycler. Whatever I left in the old garages hidden attic stayed there until they bulldozed it.
Many of the old pics are being held hostage on Photobucket!!! Being 2017 I'm going to try and document what I can on video and store it on YouTube. I'm hoping I can learn a thing or 2 about video editing along the way, I can rebuild an engine but this video editing is foreign to me.
Some pics I still have - Shortly after I got her, sported the exact same look the last 10 years! Also a pic of my parts burb & my old hauler. And another old pic of her roomate & also my daily driver(at the time)cst10.
GIZZmotorsports on YouTube & my panel truck build
'69 c10 panel, '75 c35 flatdeck car hauler
GIZZ is offline   Reply With Quote
Old 09-02-2017, 02:32 PM   #2
GIZZ
GIZZ's Avatar
Re: 69 Panel - Project needs a name
as promised, here goes
Old 09-03-2017, 05:19 PM   #3
CG
BlahBlahBlah
Looks like a great start. As far as a name, I got nothing =) I never really got the naming thing, but lots of people here put a name to their projects so Im probably in the minority.
Monroe Swap meet May 18-19.
Mike has the same spots for the NW guys he's had forever.
Lunch time BBQ at the spaces.
If you have stuff to sell bring it along.
If you have a question PM stllookn (Mike) here via the board.
https://67-72chevytrucks.com/vboard/...d.php?t=851291
CG is online now   Reply With Quote
Old 09-12-2017, 02:16 AM   #4
GIZZ
GIZZ's Avatar
Thanks! I can't wait to get to your stage of the build. Out of my 50+ vehicles I've only named one, and that was back in high school. I usually just refer to them by color.
Well, pulled the trans yesterday. So engine and trans are now out.
Got front and rear brakes in the mail, this is the first time I've see a c10 front disc brake rotor setup like this. Also the only 6 lug front with 1/2-20 wheel studs I've seen in a kit. I'm hoping the front and rear rotors are off the shelf items somewhere local to me.
Old 09-17-2017, 11:19 PM   #5
GIZZ
GIZZ's Avatar
pulled the front clip today, by myself.
http://www.youtube.com/watch?v=Twtvf...youtu.be&t=13s
Also check out this(water leak?)mod the previous owner did??? It can't be stock, I should get rid of it all?
http://www.youtube.com/watch?v=Me1G9...ature=youtu.be
Old 09-18-2017, 12:07 AM   #6
CG
BlahBlahBlah
My av picture is just a computer rendering.
Old 10-17-2017, 01:17 AM   #7
GIZZ
GIZZ's Avatar
Comparing crossmembers
Pulled the orig crossmember out for cleaning this afternoon. Torn as to which one to use. The top one is from a 1/2 ton 2wd ‘91 Suburban. The lower one, still dirty is from this ‘69 panel. I had to weigh them both twice cuz I wasn’t sure of the 8.5lbs difference in weight.
I’m also not sure if I want to run the rubber control arm bushings or the older arms and solid bushings. I used to daily drive a ‘68 on solid and I never had an issue with the ride. I like the added caster of the newer setup, but I think I can drill the lower shafts to get this.
Any suggestions?
Old 11-16-2017, 06:23 AM   #8
GIZZ
GIZZ's Avatar
In trying to decide what parts to use I figured out there is caster to be gained with the newer crossmember. The upper control arms mount further back on the squarebody crossmember vs the older one. I'm comparing '69 to a '91 suburban here. So there's your caster, unless of course the locating pin for lower arms isn't also moved back on the newer x member!
Here's what I'm talking about. Maybe ignore the exact #'s on x member weight differences, I was going by memory. Older x member really closer to 8.5 lbs lighter. The 4 older control arms also about 17# lighter than newer ones.
Old 09-13-2018, 12:05 PM   #9
GIZZ
GIZZ's Avatar
Spent a couple of hours in the shop yesterday, pulled the body back off the frame and proceeded to remove old undercoat. I was mostly using an oscillating tool with a flat metal blade, simple green in some spots then the most caustic brake clean I have(this stuff strips pain). Any tips and suggestions? If I have some decent weather on my next days off I want to roll it outside and hit it with the pressure washer and maybe the sand water blaster.
I really wanted to paint the frame with Rustbullet, and at this point I will. In hindsight I should have skipped this step and got to swapping the body mounts, new brakes and driveline.
Watch these pics be upside down...
Old 10-18-2018, 11:17 AM   #10
GIZZ
GIZZ's Avatar
Honestly if there’s a next time I’ll either send it out for powder coating or just skip the frame entirely and get to the mechanicals. Here are 3 coats of rustbellet auto silver followed up with 1 coat of black shell topcoat. Can’t wait to start installing the new driveline.
Old 10-18-2018, 01:47 PM   #11
Burb
Coordinator of Synchronicity
Burb's Avatar
... looking good
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 11-05-2018, 02:26 PM   #12
GIZZ
GIZZ's Avatar
Originally Posted by Burb View Post
... looking good
Thanks! I should show this to the wife!
Got the body temporarily on the frame in order to work on... the wife’s car.
I’m liking this low look but it’s currently laying on frame with no rear springs but tall farmtruck tires. I like the tall tire look but may end up running 295/50-15’s on the street and use my leftover 28” M&H at the track. I wish they made more 15” sizes.
Old 12-21-2018, 12:04 PM   #13
GIZZ
GIZZ's Avatar
Well, my brake kit mounting drama is just about over. Not completely happy with it. It's over in the suspension forum, http://67-72chevytrucks.com/vboard/s...d.php?t=777064
So frustrating these brake kits are so bad, so many things needed to be touched to get it all fit. Now for the future replacement parts will need modding before install. And I have no idea where these rotors are from although 80 k10 front look like the may fit all around with bracket shimming. I'm wanting to take some time off from the c10. I've been looking at c6 z06's again but may pick up a 4th gen camaro to turbo for street/strip in 2019. I figure I'd drive it more with good brakes, possibly a/c and a functioning stereo vs getting my '69 acadian(Nova) back on the road.
Old 12-24-2018, 10:11 PM   #14
GIZZ
GIZZ's Avatar
This is almost driving me to buying a newer car, I looked at a c5 z06 and took a c6 z06 for a test drive. Not too shabby.
Here is my near final summary of these brake kits, all bolted up. Need to get it all plumbed and running for a final review.
Old 12-24-2018, 10:54 PM   #15
3drburb
That last video was tough to watch, it's not good that you are dealing with this on your project.
Maybe take a very short break ( a couple days to do something else other than work on the panel ) then try contact the company with your situation, hopefully they have a way to make it work better for you and can also give you the needed replacement parts information.
They could have also sent you an incorrect part for that application.
Best wishes as you try to stay motivated on the project.
Nice panel btw.
3drburb is offline   Reply With Quote
Old 12-25-2018, 12:57 PM   #16
pwdcougar
pwdcougar's Avatar
Unbelievable that they send you a “kit” that you pay top dollar for and it requires all these mods. It’s great that you have the ability to make it work but it stinks that they are selling such a pile of crap.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-25-2018, 11:10 PM   #17
GIZZ
GIZZ's Avatar
Thanks guys for the encouragement! It really helps to hear it. I had some feedback on YouTube, another guy had to open the rotor up the same. He hasn't finished fitting them so he's now on the look for these other issues.
Took a little time to work on my car yesterday, other than that it's eating season! Merry Christmas everybody!
Old 01-06-2019, 02:05 PM   #18
GIZZ
GIZZ's Avatar
Time to modify the GM engine stands, figured I better button up the engine and have it ready to go. I swapped in the crane cam and did a basic how to vid on valve spring install, making vids is becoming my new hobby! Then I spent a half hour looking for my puller to change the crank timing chain sprocket.
Old 08-04-2019, 05:59 PM   #19
GIZZ
GIZZ's Avatar
After months I spent yesterday working on this. It's a roller again, for the time being. I uncovered some rusty spots yesterday. In attempting to swap out one front cab support I found issues. It looks like i'll be sectioning and replacing the outer of the right outer rocker panel, the front pillar where it bolts to also needs replacing.
Also while cleaning up the firewall I removed the previous owners fiberglass drip channel in the firewall drip channel, revealed a rust hole.
I took this vid of the days work, check out the spot welds on the firewall. So deep, 2 hole that go right through!? But no rust there?? I'm sure the firewall is original. So odd that this factory defect wasn't at least filled with sealer?
