01-30-2020, 11:59 AM | #1 |
Deleting heat riser?
I'm deleting a heat riser on an 83 c10 with a 305.Can I just put the exhaust pipe to the manifold or am I going to have to keep the heat riser and just gut it?I already have different studs for the exhaust manifold.
01-30-2020, 01:43 PM | #2 |
Re: Deleting heat riser?
01-30-2020, 02:36 PM | #3 |
I just put continuous vacuum to the heat riser valve so it will stay open when engine is running instead of waiting on some thermal vacuum switch to do it. I think in my old Nova in high school I just wrapped bailing wire around it to keep it open.
79 Chevy 2wd BIG10 350 TH400 |
01-30-2020, 04:24 PM | #4 |
Do you need it for smog in California? That is part of the visual inspection. You can always just cut out the flap in there and keep it. They do not need to know it works. But if you don't, I think they make a spacer.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
01-30-2020, 05:11 PM | #5 |
I'm in Oklahoma so no smog.I would just like to completely get rid of it.I already have shorter exhaust studs laying around and don't want to spend the money on the longer studs.Alot of the exhaust tubing will be replaced.I didn't know if the donut will will work without the heat riser.Also is there a difference between the driver side and passenger side exhaust manifold donut?I noticed they reach. have different style of openings.
