Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-12-2020, 07:53 PM   #1
04ls1gto
Painting 71 suburban
I am having the body of my Suburban blasted, how many gallons of epoxy primer do I need to cover outside and inside?
04ls1gto is offline   Reply With Quote
Old 10-12-2020, 09:35 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Painting 71 suburban
id think a min of 2gal..
i think I used almost 3 on my truck..but I did everything, frame and all..theres a decent recoat window for epoxy, so if you run short you can get more to finish if needed...unless your buying off the net..a burb has a lot of surface area
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-13-2020, 07:58 AM   #3
nsb29
nsb29's Avatar
If you’re just doing the exterior of the suburban 1 gallon of SPI makes 2 gallons on reduced I think would be enough but if you’re doing the inside of everything you would probably need to buy 2 gallons which will make you 4 I painted the upper half Which was the roof and upper part of the doors on my friend 64 suburban and it took a gallon With a 4/2/1 Reduction which makes you a gallon and 3/4 I gave it four coats
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 10-13-2020, 07:15 PM   #4
04ls1gto
thanks, I think ill get 2 gallons and reducer to be on the safe side
Old 10-13-2020, 08:52 PM   #5
HAULIN' IT
What kind of "blasting" are you having done?
HAULIN' IT is offline   Reply With Quote
Old 10-13-2020, 09:21 PM   #6
04ls1gto
Not sure the media he is using but be does a combo of wet and dry
Old 10-13-2020, 11:17 PM   #7
mongocanfly
Hopefully he won't warp your body panels...they used coal slag on mine..it worked great, but they still messed my door la else up...I've got more hrs in repairing them than I do in all the rest of the trucks body work.
Sad thing is they were perfect when I dropped them off..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-14-2020, 08:55 PM   #8
HAULIN' IT
Ding, Ding, Ding! That's where I was heading. You need to be concerned with what is being used & it would be a good idea to get references from people that are "like-minded" with similar projects (hobby vehicle restoration) NOT a farmer with old tractor wheels that got blasted there. The wrong guy with the wrong (very powerful) equipment &/or products (too rough/sharp) of grit can ruin your entire vehicle...& charge you for having them do it!
No Way I would let them start with the shell, Hood, ect. Take them the rad support & inner fenders...get them back & in epoxy. Then the fenders & maybe the rear doors/gate...get them in epoxy & whatever product you are going to use for blocking. Work them out some, by then you will know if they are the right person for the Hood, Doors & Roof. My Two Cents, Lorne
Old 10-14-2020, 09:17 PM   #9
04ls1gto
Thanks for the words of caution, he was recommended by the owner of body shop. I have taken more then a few of my vehicles to him and his work is awesome. I will get more info on what he uses for media
