01-18-2017, 01:30 AM | #1 |
Starter motor
Good morning!
Now that I soon got my 350 transmission installed, I need to get a new starter. I need tips on which one I should bye. My motor is a 305 smallblock. |
01-18-2017, 09:54 AM | #2 |
Re: Starter motor
you will have to check your engine block it has either a staggerd or strait bolt pattern and also the tooth count on the flywheel but you can get one of those mini high torque starters that will fit either
01-18-2017, 12:36 PM | #3 |
Re: Starter motor
What transmission did you replace for the t350?
01-18-2017, 01:14 PM | #4 |
Re: Starter motor
01-18-2017, 01:25 PM | #5 |
Re: Starter motor
Was your original starter bolted to the engine block or the bell housing? and what diameter flex plate do you have
01-18-2017, 01:41 PM | #6 | |
Re: Starter motor
Will 3hp be enough, do you think? The truck is supposed to be driven only in the summer as a cruiser. |
01-18-2017, 09:57 PM | #7 |
Re: Starter motor
168 tooth or the 14'' plate will take the same starter as the 350 with the diagonal mounting bolts
