Old 02-14-2020, 02:49 PM   #1
1972ochre4x4
67-72 blazer fuel tank electric fuel pump
Has anyone put an electric fuel pump in a 67-72 k5 tank ? I have found later 87 tank info but nothing on 67-72 tanks. I already have fuel tank mounted.
P.S.- I am running a 5.3
1972ochre4x4 is offline   Reply With Quote
Old 02-14-2020, 07:23 PM   #2
Thealien
Thealien's Avatar
Re: 67-72 blazer fuel tank electric fuel pump
Bumping as I am interested in answers. On a new tank it probably wouldn’t be too difficult to weld in a later model pump bung/receptacle (what is it really called) so an easily obtained GM pump assembly can be used?
Tanks inc has a couple of solutions also.
https://www.tanksinc.com/index.cfm/p...=cat/cat61.htm
Old 02-15-2020, 10:45 AM   #3
jaros44sr
jaros44sr's Avatar
[url=https://flic.kr/p/2hp6Aar]20191002_093933
I had a shop weld in a tray to mount mine, seems the most problem I had was the locking ring to keep it in the tank. There is a universal locking system now available thru out the industry
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-15-2020, 10:58 AM   #4
1972ochre4x4
What pump did you use?
Old 02-15-2020, 01:16 PM   #5
jaros44sr
jaros44sr's Avatar
[url=https://flic.kr/p/2hojACa]20190930_180411
It's more the mounting bracket then the pump, but my pump puts out 55psi
SAFETY FIRST
AS usual, off topic
Jim
Old 02-15-2020, 01:20 PM   #6
jaros44sr
jaros44sr's Avatar
[url=https://flic.kr/p/2hk9x9E]20190924_074530
the ss gets welded to the tray, and the black locking ring is installed on top of it. While you're in there, I would change the neck on the tank
SAFETY FIRST
AS usual, off topic
Jim
Old 02-15-2020, 05:07 PM   #7
1972ochre4x4
I found this ring which seems to be pretty straight forward and easy
Old 02-15-2020, 07:29 PM   #8
jaros44sr
jaros44sr's Avatar
sorry, but I have no idea, how they work and how you mount the pump. I says adapters, so, what does it adapt?
The company I used was called Vapor Worx
SAFETY FIRST
AS usual, off topic
Jim
Old 02-16-2020, 10:37 AM   #9
1972ochre4x4
This is a weld in tank ring and is only $66
https://vetteworksonline.com/catalog...products_id=89
https://www.vetteworksonline.net/ls1...rsion_fuel.htm
Also what did you mean by change tank neck?
Old 02-16-2020, 11:28 AM   #10
Thealien
Thealien's Avatar
If you look at your tank the fuel fill is a short straight piece of piping/tube. Originally on 1969-1972 Blazers and Jimmy's the fuel filler neck had a bend that kind of goes around the body mount. Previously we would remove the ones from our original tank and solder it onto the new tank. There is now a tank with the correct fuel fill. This is on Blazers not pick up trucks.
We do have the gas tank part # 69-10710 $165.00
Thank you
Truck and Car Shop
739 N Batavia St.
Orange CA 92868
714-771-7871 (phone)
800-235-2470 (phone)
714-771-0407 (fax)
www.truckandcarshop.com
Old 02-19-2020, 04:46 PM   #11
1972ochre4x4
I decided to go with a tanks inc pump as it will bolt in no welding
