02-15-2020, 09:05 AM | #1 |
*Servicing a 350 Turbo*
I have a 2001 5.3 Vortec engine with a 350 turbo (year unknown) in my 49 pickup. The transmission is leaking I believe from the pan gasket and the shifter shaft seal. I am not having any issues with the transmission and it shifts fine. I just got this truck about 4 months ago so I want to take it in and have the transmission serviced. I did this on a car some years ago and they flushed the transmission out and it never did shift right after that. I had to have it rebuilt. I fear the same thing may happen again. I was thinking of just having the fluid, filter, & gaskets changed along with the shifter shaft seal. What are your thoughts?
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
02-15-2020, 01:07 PM | #2 |
Re: *Servicing a 350 Turbo*
If everything is working OK. Just change the fluid new pan gasket and shifter shaft seal. Then call it a day. I would not flush it
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-15-2020, 10:30 PM | #3 |
Just drop pan change filter and pan gasket and shifter seal fill back up do not flush
02-16-2020, 08:52 AM | #4 |
Sounds like a plan guys. Thanks.
02-16-2020, 12:20 PM | #5 |
There is lots of stuff on Youtube on rebuilding the TH350. You may get a clearer picture of what to do.
02-20-2020, 04:44 PM | #6 |
Well I talked to some of the local boys about what transmission shop treats us AD owners the right way. Made the call today to get a price on fluid change (NO FLUSH OUT), shifter shaft seal replacement, filter, and gaskets. $150 to $200. Thought that was pretty reasonable. I just hate leaving the truck over night.
02-25-2020, 07:53 PM | #7 | ||
"I ain't nobody, dork."
Do it yourself, catch the transmission fluid in a clean pan (to reuse), change out the gasket and shaft seal, and call it a day. Gasket and seal will set you back about $30 bucks.
The shaft seal can be a bugger. but it's doable for a shadetree... Gary
02-27-2020, 01:40 PM | #8 |
Well....I'm a big shade tree and just not a fan of jacking the truck up and crawling around on the garage floor anymore. I would pay for it the next couple days.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 02-28-2020 at 01:39 PM. |
02-27-2020, 10:03 PM | #9 | ||
Okey doke! Hope they get 'er done for you.
Gary
