01-28-2020, 10:45 PM | #1 |
Rear bumper bracket holes
I am currently fixing the rear frame rails on my ‘88 V30. I noticed that I have two sets of rear bumper bracket holes (1 1/4” apart) for my sport bumper. Could anyone recommend which set I should be using? I trimmed the rear frame rail, but can add material back if I should be using the front set. Thanks.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
01-29-2020, 09:46 PM | #2 |
Re: Rear bumper bracket holes
Anyone able to help with this?
01-29-2020, 10:19 PM | #3 |
In this video I remember the fabricator talking about two sets of holes and which ones to use according to year......good info that might can help you......
https://www.youtube.com/watch?v=AvfLJ0m0GE8
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
01-30-2020, 11:33 PM | #4 | |
02-09-2020, 07:16 PM | #5 | |
Can anyone provide a measurement from the rear edge of the frame rail to their bolt holes?
02-16-2020, 02:11 PM | #6 |
I got some pics for you from my dually. I added some text to help w/the numbers. 1, 2, & 3 are the bolts that retain the inner & outer brackets on mine.
#3 is approx. 5" from the edge of the frame rail & only goes through the last hole on the inner/longer bracket. #2 is approx. 1.5" from the edge of the frame rail. #1 & #2 go through both inner & outer brackets.
02-20-2020, 09:43 AM | #7 | |
