Old 02-07-2020, 01:18 AM   #26
burnin oil
Re: 292 i6 in place of 6.5 diesel.
Originally Posted by D13 View Post
Motor stands on the frame - if you find a set send them to me. I have never seen the 292 4wd combo in person. 250 4wd versions are rare enough that I plan to make my own, and I don't know if 292 versions interchange with them. I believe they are not directly interchangeable with 2wd stands. And each frame package has its own unique height and thickness.
Whee!
Older post I know but I have seen this combo. My old neighbor had one. 292 with the goofy 2 barrel carb, 4spd, 4x4. He bought it new so I know that it wasn't swapped.
burnin oil is offline   Reply With Quote
Old 02-18-2020, 07:21 AM   #27
'68OrangeSunshine
'68OrangeSunshine's Avatar
292s in K-Series trucks required a special, 292-only diagonal cross-menber.
Mine's not for sale, but I could give the measurements, and someone could weld a facsimile. The diagonal runs from the drivers-side back, to passsenger side forward. Probably runs under the motor mounts. C-Series frames must be closer together near the front.
'68OrangeSunshine is online now   Reply With Quote
Old 02-22-2020, 01:36 AM   #28
whitedog76
The 6.2/6.5 engines use a Big Block crossmember. Just a thought..
whitedog76 is offline   Reply With Quote
