02-14-2020, 02:49 PM | #1 |
67-72 blazer fuel tank electric fuel pump
Has anyone put an electric fuel pump in a 67-72 k5 tank ? I have found later 87 tank info but nothing on 67-72 tanks. I already have fuel tank mounted.
P.S.- I am running a 5.3 |
02-14-2020, 07:23 PM | #2 |
Re: 67-72 blazer fuel tank electric fuel pump
Bumping as I am interested in answers. On a new tank it probably wouldn’t be too difficult to weld in a later model pump bung/receptacle (what is it really called) so an easily obtained GM pump assembly can be used?
Tanks inc has a couple of solutions also. https://www.tanksinc.com/index.cfm/p...=cat/cat61.htm
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
02-15-2020, 10:45 AM | #3 |
[url=https://flic.kr/p/2hp6Aar]20191002_093933
I had a shop weld in a tray to mount mine, seems the most problem I had was the locking ring to keep it in the tank. There is a universal locking system now available thru out the industry
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-15-2020, 10:58 AM | #4 |
What pump did you use?
02-15-2020, 01:16 PM | #5 |
[url=https://flic.kr/p/2hojACa]20190930_180411
It's more the mounting bracket then the pump, but my pump puts out 55psi
02-15-2020, 01:20 PM | #6 |
[url=https://flic.kr/p/2hk9x9E]20190924_074530
the ss gets welded to the tray, and the black locking ring is installed on top of it. While you're in there, I would change the neck on the tank
02-15-2020, 05:07 PM | #7 |
I found this ring which seems to be pretty straight forward and easy
02-15-2020, 07:29 PM | #8 |
sorry, but I have no idea, how they work and how you mount the pump. I says adapters, so, what does it adapt?
The company I used was called Vapor Worx
02-16-2020, 10:37 AM | #9 | |
This is a weld in tank ring and is only $66 https://vetteworksonline.com/catalog...products_id=89 https://www.vetteworksonline.net/ls1...rsion_fuel.htm Also what did you mean by change tank neck? |
02-16-2020, 11:28 AM | #10 |
If you look at your tank the fuel fill is a short straight piece of piping/tube. Originally on 1969-1972 Blazers and Jimmy's the fuel filler neck had a bend that kind of goes around the body mount. Previously we would remove the ones from our original tank and solder it onto the new tank. There is now a tank with the correct fuel fill. This is on Blazers not pick up trucks.
We do have the gas tank part # 69-10710 $165.00 Thank you Truck and Car Shop 739 N Batavia St. Orange CA 92868 714-771-7871 (phone) 800-235-2470 (phone) 714-771-0407 (fax) www.truckandcarshop.com
02-19-2020, 04:46 PM | #11 |
I decided to go with a tanks inc pump as it will bolt in no welding
