Old 02-15-2020, 09:05 AM   #1
Zippi
Zippi's Avatar
*Servicing a 350 Turbo*
I have a 2001 5.3 Vortec engine with a 350 turbo (year unknown) in my 49 pickup. The transmission is leaking I believe from the pan gasket and the shifter shaft seal. I am not having any issues with the transmission and it shifts fine. I just got this truck about 4 months ago so I want to take it in and have the transmission serviced. I did this on a car some years ago and they flushed the transmission out and it never did shift right after that. I had to have it rebuilt. I fear the same thing may happen again. I was thinking of just having the fluid, filter, & gaskets changed along with the shifter shaft seal. What are your thoughts?
If you can't fix it with duct tape, it's an electrical problem.
1949 5 Window 3100
https://zippi6.wixsite.com/adtruck
Zippi is offline   Reply With Quote
Old 02-15-2020, 01:07 PM   #2
tdangle
tdangle's Avatar
Re: *Servicing a 350 Turbo*
If everything is working OK. Just change the fluid new pan gasket and shifter shaft seal. Then call it a day. I would not flush it
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-15-2020, 10:30 PM   #3
truckdude239
truckdude239's Avatar
Just drop pan change filter and pan gasket and shifter seal fill back up do not flush
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-16-2020, 08:52 AM   #4
Zippi
Zippi's Avatar
Sounds like a plan guys. Thanks.
1949 5 Window 3100
Old 02-16-2020, 12:20 PM   #5
vince1
There is lots of stuff on Youtube on rebuilding the TH350. You may get a clearer picture of what to do.
vince1 is offline   Reply With Quote
Old 02-20-2020, 04:44 PM   #6
Zippi
Zippi's Avatar
Well I talked to some of the local boys about what transmission shop treats us AD owners the right way. Made the call today to get a price on fluid change (NO FLUSH OUT), shifter shaft seal replacement, filter, and gaskets. $150 to $200. Thought that was pretty reasonable. I just hate leaving the truck over night.
1949 5 Window 3100
Old 02-25-2020, 07:53 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Do it yourself, catch the transmission fluid in a clean pan (to reuse), change out the gasket and shaft seal, and call it a day. Gasket and seal will set you back about $30 bucks.
The shaft seal can be a bugger. but it's doable for a shadetree...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-27-2020, 01:40 PM   #8
Zippi
Zippi's Avatar
Gary
Well....I'm a big shade tree and just not a fan of jacking the truck up and crawling around on the garage floor anymore. I would pay for it the next couple days.
1949 5 Window 3100
Old 02-27-2020, 10:03 PM   #9
GASoline71
GASoline71's Avatar
Okey doke! Hope they get 'er done for you.
Gary
