05-30-2020, 10:23 PM | #1 |
Old member
Stock 350
Been playing with the 64 SS Impala today. I had problems with it running ok then not so much. I have set the timing I don't know how many times on it. I keep setting it at 8* BTDC with vacuum plugged off.
It will idle just fine. It will drive just fine for several days. Then it's like somebody moves the timing on it. Not much but enough to make it sputter when you give it the gas while driving it. I just finished setting it again. I'm wondering if it is the hold down bolt? I tighten it down good but don't want to strip the threads since it's aluminum intake. It's like 1-2 degree off each time. Could it be the springs maybe in the dizzy? Give me some idea's I really want to get this straight before I sell it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-30-2020, 11:57 PM | #2 |
Re: Stock 350
Is it 1 to 2 degrees retarded when you check it. A loose distributor will rotate clockwise when loose.
Is this a points distributor? What’s the idle rpm when hot? |
05-31-2020, 08:00 AM | #3 |
Re: Stock 350
I helped a friend with one and his was similar issue. Problem with his was the distributor hold down seemed to be soft metal and it would flex and slowly bend thus allowing the distributor to work loose and get the timing off. Found and old hold down clamp in my stash and it worked good after that.
05-31-2020, 09:00 AM | #4 |
Re: Stock 350
I too had similar problems like that and changed to a old style dist. clamp,also check the clamp is fully on the dist.,had that problem too ,couldn,t see that only one ear of the hold down clamp was touching the dist. Kinda hard to see back there sometimes.
05-31-2020, 04:33 PM | #5 |
Old member
Re: Stock 350
HEI no points. Yea it always seems to be retarded.
The hold down is what was on it when we bought it a chrome hold down! This maybe it then. I will get a stock one and try it. Thanks guy's.
05-31-2020, 07:05 PM | #6 |
Re: Stock 350
I had a car that had the advance weights sticking in a slightly advanced position and throwing off my settings. I doubt that the hold-down bolt is the culprit. Lube the weight pivot points (carefully). -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
05-31-2020, 07:22 PM | #7 |
Re: Stock 350
Mark it with a couple paint dots after you try out the new hold down to see if that was it for sure.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
05-31-2020, 08:30 PM | #8 |
Old member
Re: Stock 350
Good idea Jesse.
06-06-2020, 09:32 AM | #9 |
Re: Stock 350
Had a 292 that was doing the same thing untill it finally wouldn't run well at all. Ended up being the gear on the distributor was moving .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-06-2020, 11:23 AM | #10 |
67-72 parts collector,…
Re: Stock 350
Use a stud and nut instead of a hold down bolt.
The stud will fully engage the threads of the aluminum intake and prevent stripping the threads.
