05-17-2020, 06:49 PM | #26 | |
Re: How to create older restoration quickly
05-27-2020, 08:52 AM | #27 |
Have you ever wondered why we put between 7 and 12 coats of paint on the outside of the car but only one or 2 coats underneath? Another question why would you use a coating system that failed the 1st time. The one that is available today in most cases is not is good as" we had in the past.. Think about it.
05-27-2020, 11:22 PM | #28 | |
You can pay attention to what you can see. Much less of attention is paid to what you can not see. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
05-28-2020, 06:51 AM | #29 |
I had a car buddy and his brother worked in a refinery (PPG I think) in Lake Charles, La and he was painter. Part of his job included trucks used only in the refinery, and the environmment was extremely corrosive. They hit everything with Ospho after removing loose scale, then primed and painted with enamels. He said it worked quite well. It was my first exposure to phosphate treatments. I've only used phosphates on really rough metal, nothing above the floorboards.
Rustoleum paint has an interesting story. The use of fish oil in primers resulted from areas on fishing boats that did not rust because the fish were cut and processed by hand back then and these areas always had fish guts on them. The Rusty Metal Primer does work. |
05-28-2020, 07:35 AM | #30 | |
05-28-2020, 08:16 AM | #31 |
Excellent point. A year after I painted this car I get bit in the trunk.
05-28-2020, 08:19 AM | #32 |
This is where a good quality rust remover is used to soak the seams and then coat: with the quality sealer. As for flexibility industrial coatings to have flexibility everything moves in one way or another
05-28-2020, 08:59 AM | #33 |
I have been getting powder coat done by an industrial coatings specialty company for a long time. I mostly had heavier metal powder coated, but they use different products for different uses. For instance, epoxy. I really wanted that because epoxy is better, right? Turns out that depends. They only use epoxy for interior pieces and use poly-based for exterior. For UV resistance but also temp variation. The epoxy doesn't react to temps the way metals do. It made sense to me because I used to paint the shocks on my lifted 4wds with epoxy paint and without fail that would crack and pop off in shards. That's with sandblasting first.
05-28-2020, 09:29 AM | #34 | |
