Old 09-19-2010, 09:05 PM   #1
Nukes16
Nukes16's Avatar
cab mount bolts
Can someone help me out quickly, are there nuts on the other end of the cab mount bolts, and if so, how can you get at them. I'm guessing that there are just welded on nuts on the inside, but mine seem to be really on there and are not turning that well. So I stopped spinning them to check.
Thanks in advance.
Nukes16 is offline   Reply With Quote
Old 09-19-2010, 09:09 PM   #2
HumbleChevyBuddy
HumbleChevyBuddy's Avatar
Re: cab mount bolts
There are only removable nuts on the core support body mounts. The cab mounts have weld-in nuts, since the only hardware to remove when changing the bushing is the bolt that goes in from the ground up towards the cab. I hope this helps.
HumbleChevyBuddy is offline   Reply With Quote
Old 09-19-2010, 10:57 PM   #3
Stitch
Location: Where I come from, it's cornbread and chicken...
Re: cab mount bolts
there are welded nuts up inside the body...if the bolts are spinning and not coming loose, then the nuts have come loose...you'll need to cut holes in the cab floor about the bolt inside and get something in there to hold the nut.
Stitch is offline   Reply With Quote
Old 09-20-2010, 03:59 AM   #4
swamp rat
swamp rat's Avatar
Re: cab mount bolts
Not trying to hyjack the thread but i could use some advice on this subject..
Are the welded nuts accessable for a little PB Blaster spray without having to pull the seat and carpet? In other words i'm assuming the bolts don't protrude into the cab correct? sounds like it from your posts. I have the mounts and wanna start my swap soon but want to saturate the bolts for a day or two first.
Also, is it recomended to lift the cab and front fenders as 1 unit? I don't want to damage any body parts. do i need to loosen the steering joint? all i have to work with is a large and a smaller floor jack and a couple other bottle jacks.
Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-20-2010, 07:31 AM   #5
Stitch
Re: cab mount bolts
You can't see or access the nuts or bolts from the inside without drilling holes in the cab floor. I don't think it's possible to get any PB Blaster on the joint between the nut and bolt.
Also I think it would be alot better to take the front end off the truck first.
Old 09-20-2010, 09:24 AM   #6
canadian trucker
A day should have 30 hours.
Re: cab mount bolts
You have to cut holes in the cab floor and the sill behind the seat.
Wish there was an easier way
canadian trucker is offline   Reply With Quote
Old 09-20-2010, 03:02 PM   #7
swamp rat
swamp rat's Avatar
Re: cab mount bolts
Forgot to ask, my cab mounts didn't come with bolts, i'm assuming Grade 5 would be ok?? Or should i get Grade 8?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-20-2010, 05:00 PM   #8
swamp rat
swamp rat's Avatar
Re: cab mount bolts
I thought about it, didn't want to gut the interior, was looking at the rear support and noted that there are some 3/8 holes, so i figured what could a couple little 1/8 holes angled upward hurt? so i drilled them and sprayed a bunch of Deep Creep inside, i was able to follow the bolt up to the nut with the red plactic spray tip, i figure i could allways weld the hole shut later.
Still need to know if i need to replace the mount bolts if i need grade 8 or grade 5, Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-11-2021, 10:46 AM   #9
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: cab mount bolts
well I am bringing this thread back up from the dead. I am in the process of replacing my cab bushings and ran into a stripped bolt on my pass. side rear cab mount - it feels as if the nut is spinning inside . I am guessing that the way to "fix" & replace the bushing is to cut a opening above the bolt location inside the cab (as indicated above) & then after repair and bushing replacement weld up the repair opening?
thoughts??
rodstored-72 is offline   Reply With Quote
Old 01-11-2021, 11:55 AM   #10
Mattchu60
Re: cab mount bolts
Yes, that's the only solution. I had a rear nut break loose on my C10 cab. had to use a large hole saw to cut a hole inside the cab above the nut and then find something to hold the nut with.
Mattchu60 is offline   Reply With Quote
Old 01-11-2021, 01:13 PM   #11
rodstored-72
chevy truck fan
Re: cab mount bolts
mattchu60, yea..I was thinking that would be the solution in my build thread a member mentioned that the hole saw plug could be re-welded or a plastic/rubber plug to fit the hole as well....
thanks!!
Old 01-11-2021, 07:02 PM   #12
Pontiac1976
Pontiac1976's Avatar
Re: cab mount bolts
8 Grade body to frame bolts because that holding you to the frame
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-12-2021, 07:28 PM   #13
rodstored-72
chevy truck fan
Re: cab mount bolts
Agree I would replace... I will for this repair... with grade 8 bolts & etc. it is a cheap safety measure!..
Old 01-12-2021, 09:58 PM   #14
85square
Re: cab mount bolts
I had to cut all 4 holes in my cab, two in the front, two in the back. I bought a cab and the previous owner cut the mounting bolts leaving just studs about 2" in length out of the mounts. It was a pain in the butt but not terrible. I replaced the hardware with good grade 8 stuff. I haven't gotten around to patching the holes back up but i think I'm going to just plug them with something rather than weld them back up in case i ever have to get to them again.
85square is offline   Reply With Quote
Old 01-12-2021, 10:46 PM   #15
franken
Re: cab mount bolts
I suppose it's a little late now but I tighten the bolts a bit, then back them off a little, tighten, loosen, repeat until they come out. It doesn't always work, but it's better to take some time rather than just spinning the nuts.
Wood bed strip bolts? Tighten until they shear off...
Old 01-13-2021, 12:56 PM   #16
rodstored-72
chevy truck fan
Re: cab mount bolts
I tried this as I did it, but it was to nooo avail! lol.... it can work like said... sometimes...
