Old 01-08-2013, 07:06 PM   #1
blkcorvair
blkcorvair's Avatar
Inline six spark arrestor
Anyone know if the spark arrestor is available somewhere. I cant seem to locate it in any parts houses. See pic below. I am trying to build the line that goes from the air cleaner spacer to the side of the valve cover. I think its called a spark arrestor????
blkcorvair is offline   Reply With Quote
Old 01-08-2013, 07:38 PM   #2
ruggles
Re: Inline six spark arrestor
I think that you are looking for crankcase ventilation (PCV) early style....Ruggles
ruggles is offline   Reply With Quote
Old 01-08-2013, 07:59 PM   #3
blkcorvair
blkcorvair's Avatar
Maybe? Someone else called it a spark arrestor in another thread. I do have the standard PCV valve in the back of the air cleaner. Than I have just a rubber hose that goes from the front side of the vale cover to the Air cleaner spacer. Now Im switching to a Offset air cleaner like the one above and all that I see have that line with what looks like a fat PCV valve inline. ??
Old 01-08-2013, 09:57 PM   #4
blkcorvair
blkcorvair's Avatar
Heres a better picture I found from another thread. Now Ive seen it been called a flame supressor, Breather filter etc.... Anyway Ill need to source as much of this setup as I can to run my Offset filter.
Old 01-09-2013, 12:29 AM   #5
RichardJ
Probably wrecking yard.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-09-2013, 01:18 AM   #6
WIDESIDE72
WIDESIDE72's Avatar
Theoffset air cleaners and parts are tough to find. I saw a complete offset air cleaner set up on the parts board pretty cheap. I think it had this piece. A few years back I bought an offset air cleaner for $50 but it was missing the spacer and this breather. I got lucky and found one on the parts board for $15.
WIDESIDE72 is offline   Reply With Quote
Old 01-09-2013, 05:24 AM   #7
chewychevy67
I have the arrestor filter piece. I believe the six cylender arrestor is bigger than ones used iv v8's. Will post pics if you are interested.
chewychevy67 is online now   Reply With Quote
Old 01-09-2013, 08:27 AM   #8
blkcorvair
blkcorvair's Avatar
Absolutly. Please do
Old 01-09-2013, 02:36 PM   #9
chewychevy67
i have these 2. The smaller mouth one is from a 68-72 v8 and the larger mouth is from a 67 v8 and 67 and up line 6 with optional closed pos vent. I believe the larger one is what you are looking for. I may have the rubber hoses as well but would have to look. I dont have the cleaner, spacer or the metal tube that comes out of the valve cover. Removed this so long ago that i have no idea what happened to them. Rod.
Old 01-09-2013, 05:28 PM   #10
blkcorvair
blkcorvair's Avatar
I think your'e right. What ever you can find let me know. Hoses would be good too. I can source the clamps. Ill piece this thing together slowly as I need too.
Old 01-30-2013, 11:54 PM   #11
chewychevy67
I couldn't find the hoses. Did you still want the arrestor?
Old 01-31-2013, 04:22 PM   #12
blkcorvair
blkcorvair's Avatar
Thanks, but I ended up brabbing a whole setup in the meantime
Old 01-31-2013, 04:57 PM   #13
chewychevy67
no worries. just checkin.
Old 01-31-2013, 05:20 PM   #14
blkcorvair
blkcorvair's Avatar
thanks for your trouble tho!
Old 01-31-2013, 07:53 PM   #15
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I just came across one of these if you still need one. From a 67 Chevy that had the oil bath air cleaner. All original with GM markings on hose.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-10-2019, 03:41 PM   #16
smokin and strokin
I need a 72 small V8 flame arrestor and hose
smokin and strokin is offline   Reply With Quote
Old 01-11-2019, 08:43 PM   #17
bill3rail
bill3rail's Avatar
5 Year Old Thread Dredged up yet Again...
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
