Old 06-06-2016, 01:23 PM   #1
cjrolke
changing motor mounts to 73 and up
does this modification move the motor forward more? I have the new mounts and it seems like it would. also that would mean the trans is further forward too?
thanks
cjrolke is offline   Reply With Quote
Old 06-06-2016, 01:55 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: changing motor mounts to 73 and up
Why are you changing them to 73 up ? What year is your truck?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 06-06-2016, 02:03 PM   #3
cjrolke
Sorry it is a 71
I believe that the later model style are more secure
Old 06-06-2016, 02:58 PM   #4
dennislbrooks
Will you have to change the motor stands --perches-- also to 73 up? The threads below is for a 63 c10 to 350 andan LS swap using 73 up engine clamshell mounts but gives me an idea what is involved.
https://www.google.com/search?domain...KQAVnKgLjHM%3A
http://67-72chevytrucks.com/vboard/s...d.php?t=674122
Old 06-06-2016, 07:00 PM   #5
michael bustamante
michael bustamante's Avatar
sre you doing an ls conversion also? since you have to drill new holes id the frame to mount the 73+ towers, you can pretty much mount them where you like. if you re doing the LS coversion the most popular is to use the dirty dingo slider mounts from what ive read.
im doing this very same thing now
1967custom
michael bustamante is offline   Reply With Quote
Old 06-06-2016, 09:32 PM   #6
cjrolke
i want to eventually do an LS swap but for now just a 350. When I bought the truck it did not have a motor. so I picked up one and it had the other motor mounts.
Old 06-06-2016, 09:53 PM   #7
dennislbrooks
Sounds to me that you need the 73-87 towers also to use the 73-87 clamshells for a sbc.
Old 06-06-2016, 10:12 PM   #8
firedemon
I got these from performance online with the trans mount for around 200 way cheaper I think and should be more than strong enough and theyre made to bolt in to our trucks
firedemon is offline   Reply With Quote
Old 06-06-2016, 11:41 PM   #9
sprint_9
sprint_9's Avatar
Im doing this swap myself, but I am changing to an ls engine, and converting to a short wheelbase at the same time so I have a little more freedom to modify. One thing to note is that there are two different sizes of this bracket, make sure you have the right one, sounds like you do though. This post was in the Faq section, it may help you out. http://67-72chevytrucks.com/vboard/s...d.php?t=128765
sprint_9 is offline   Reply With Quote
Old 06-07-2016, 12:06 AM   #10
ck5566
thanks
I have a 68C10 with the 73 & up Perches but my motor/trans setup is a 305/700R4. My fan blade sticks over the top of the shroud about an inch from my newly bought SBC fan shroud. I think the 73 perches moved my engine up to the hood not to the radiator like you are asking here.
Just something to think about might not be the same for you, but it might
ck5566 is offline   Reply With Quote
