Old 07-16-2019, 05:35 PM   #1
Mixup
1980 Fan Shroud W/AC
Anybody know where to get a fan shroud for a 1980 Chevy Pickup V8 with AC? Can't find one listed anywhere.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 07-22-2019, 10:30 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: 1980 Fan Shroud W/AC
Did you check them out here
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-22-2019, 10:45 AM   #3
Pontiac1976
If not then your going to have to try wrecking yard that has lots truck of the 73-80.
I think you need the top section mostly. I be leave the bottom is the same in one of the
option or will work with the top. I have to see them as I do not remember any more It's been along time I checked that out. If it the None a/c or the a/c option can work.
Old 07-22-2019, 11:19 AM   #4
Dannyboy1966
Dannyboy1966's Avatar
I believe the only difference between the two are the one for AC has two towers molded in the top so you can clamp the lines to the top of it.
Dannyboy1966 is offline   Reply With Quote
Old 07-22-2019, 10:48 PM   #5
82Diesel
Good thing you don't need one for a 6.2L diesel they are almost impossible to find! I don't know much on Gas Specific parts though! Best luck Maybe some Aftermarket websites, like LMC/USA1/Classic Industries etc... or Yes the local Wreaking yard.
82Diesel is offline   Reply With Quote
Old 08-07-2019, 08:46 PM   #6
Mixup
Called LMC, they don't have one and they don't know of anybody that does. The A/C radiator is taller and the non A/C is shorter.
1969 Z28 engine
Turbo 350
