09-26-2020, 02:53 PM | #1 |
Desk building help
I’m going to build a floating desk. It’s going to be 10’ on one wall & 6’ on the other. I’m using 3/4” birch plywood. I’m building 2 base cabinets ( 3/4” birch ply 21”W x20”D x 26”T) for it to set on. I’m thinking a 2”x4” ledger board on the long wall to support the rear of the desk top (3/4” birch plywood 24”deep) & using these mounted to the bottom & going about 45 degrees(or so)to the wall every 16” on studs. I’m putting a 1”x2” (or whatever looks best) on the front,sides & rear of desktop plywood.I’m wondering about the top sagging. Do you think I have enough stiffness?
https://www.simplifiedbuilding.com/p...-swivel-flange
Great minds think alike,So do ours |
09-30-2020, 07:51 AM | #2 |
Re: Desk building help
I'm not sure I have the picture right. Are the two base cabinets at either end? I'd want a ledger along the wall under both sections of the top. By "these" you mean those mounts you gave a link to, right? I don't follow what you will do with those. Are you thinking support the top's spanned area? How long would those be? How will you join the two sections at the inside corner? I'm thinking you need good support at the end of that long section (8'). really, support for either side at that point. I think you need something strong and rigid to span from the base of the 6' section to the wall at the back of the long section, then the same sort of support to span from the base cabinet into the shorter support. These would be under the top, could be set back some so not to be seen. That edge trim board should be oak or other hardwood to help with strength as well
09-30-2020, 12:01 PM | #3 | |
"Tail Gate Best Seat In House"
If you put a 2x4 ledger on both the 10 and the 6 foot walls at the rear and a 1"x 2" all along the front ,,,with them braces every 16 " located out towards the front of the desk top underneath..that will do the job and I would not worry about warping ,, I acually would build it and put in these braces as needed ,,,,,maybe every 32 " ?? and sit a cabinet at each end underneath the desk top .. then ,, you are good to go .. the only weak point is the inside corner like Tim mentions ( if you have a stud in the wall so you can put one of them braces right up under the two desk top joints with a 3/4 " plywoood to cover the joint ..thats one way to keep the joints even with each other..
When you learn a thing a day you store up smart. |
10-01-2020, 10:00 AM | #4 |
I don't know the intended use. Those supports will do the trick. What I was thinking is if you needed that area open under the desk, the braces would clutter the area, limit it. When I think desk I think sitting and leg space, like a table. To have a free-span area would be ideal, so that is how I was thinking on support.
10-04-2020, 06:42 PM | #5 | |
10-04-2020, 06:45 PM | #6 | |
Ya my main concern is that joint where the two boards will meet.
10-04-2020, 09:54 PM | #7 |
That's how I pictured it. I'm wondering your intended use. Desk or more like a work bench, meaning heavier use. What I wonder is if you want the desk open underneath for leg room, won't the angle supports limit the free space? I described a way to keep it open under there. I'm sure you've thought it out and know what space you need underneath
10-06-2020, 06:16 PM | #8 | |
