12-03-2020, 07:32 AM | #1 |
1995 intermittent popping through speakers
1995 Chevy truck, 350tbi 73k orig. miles. This just started a week ago. Sometimes while driving there will be a popping sound that comes through speakers when the brake is applied, turn signal, etc. Lights on the dash will flash and the idle will drop. I know it is electrical but not sure where to start. Sometimes just sitting at a traffic light it will pop and almost die. Thanks for the input.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
12-03-2020, 07:37 AM | #2 |
Re: 1995 intermittent popping through speakers
Sounds like a short somewhere....
12-03-2020, 08:20 AM | #3 |
Agreed, truck does have trailer brake and mount for snowplow. The snowplow wiring is disconnected.
12-03-2020, 08:27 AM | #4 |
I'd look around for a bad ground as well. There should be a big cable from the battery to the intake manifold, a smaller one to the fender, and one on the back of the passeger side head to the firewall. There are also ground points on the inside of the firewall.
Mike |
12-03-2020, 08:53 AM | #5 |
Maybe when the snowplow was disconnected it effected the ground connection.
12-03-2020, 09:21 AM | #6 |
I will give it a good look later today. Thank you.
12-04-2020, 12:32 PM | #7 |
The grounds and battery cables all appear to be in good condition. While driving last night with the cruise on, went to signal a lane change and it popped and kicked out the cruise and dash warning lights flashed. The battery has a double connection on the positive terminal, one cable to the starter another goes to the fuse/power box on the driver side engine compartment. This looks to a factory cable, does this sound correct?
12-04-2020, 02:13 PM | #8 | |
Mike |
12-04-2020, 02:13 PM | #9 |
Sounds correct
