06-25-2019, 02:31 PM | #1 |
Continuing Temperature Gauge Issues
I have been having strange temp gauge problems. Seems to really float around going from barely warm to almost hot and back within a few seconds. I have verified the temp of the engine with a thermal gun and it is fine. I have a new 180 thermostat, new sending unit (actually have 3 new units). I know as the sending unit goes to ground the gauge reads hotter. Couple of days ago the gauge dropped to cold and I figured the wire came off of the sending unit. I turned the ignition off and for some reason I turned it right back on with out even starting the engine. Gauge went from cold to normal. cycled the ignition switch a few times and gauge reading varied. First I was thinking the power to the instrument panel has an issue, but the fuel gauge reads correctly all the time. Is it possible I have a flaky temp gauge? I really don't want to just throw new parts at it with out somehow verifying the problem.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
06-25-2019, 03:24 PM | #2 |
Who Changed This?
Re: Continuing Temperature Gauge Issues
My temp gauge did the same sort of thing, and my fuel gauge works fine, too. I put in a mechanical gauge that I bought for a car I ended up selling. I'll get to making it "right" eventually.
06-25-2019, 03:42 PM | #3 |
Do you have the heater core hooked up? If not do you have a bypass hose in its place?
06-25-2019, 04:41 PM | #4 |
Yes all stock AC/Heater. Gen1 SBC had an internal bypass in the head. I've also turned the heater on to see if it made a difference. As far as I can tell the engine temp is not really changing much per the thermal gun. As soon as I started seeing a change in the gauge reading by just cycling the ignition switch I realize it's not a cooling problem its a gauge problem.
06-25-2019, 04:42 PM | #5 |
At least now I know I'm not going crazy.
06-25-2019, 08:50 PM | #6 |
Who Changed This?
Usually, when the gauge goes nuts, especially if it indicates low, the system is low on water. I ran the gauntlet with mine during trouble shooting. Like you, I could tell it wasn't over heating.
06-25-2019, 11:08 PM | #7 | |
It worked great until one day the sending unit went out and from that point on it has been driving me nuts. When its reading correctly (which is actually most of the time) it maintains the same temp whether on the highway or around town, AC on or off.
06-25-2019, 11:44 PM | #8 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-26-2019, 02:50 AM | #9 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Check your grounds, ALL of them. A greasy ground connection will fluctuate resistance...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-26-2019, 04:07 AM | #10 | |
Paul Sr @ GMCPauls |
06-26-2019, 06:19 AM | #11 |
Another thing I've heard. Use pipe dope instead of teflon tape, as the tape will not allow it to conduct as well.
Manifolds or headers? Heat shields? Does the connector fit firmly onto the sensor?
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
06-26-2019, 01:09 PM | #12 | |
Going to work on it this weekend and hopefully figure it out. Will keep you all updated.
06-28-2019, 11:34 PM | #13 | |
Cluster King
"It worked great until one day the sending unit went out" What type of sending unit did you replace with? I would not be surprised if you got a bad one right out of the box. You may consider trying a different one to see if the condition changes. I have a hard time trusting new parts these days.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
06-29-2019, 12:52 AM | #14 |
Just had a buddy who went thru the same issue, his was reading warmer than normal but the heat gun said all was good. 2 senders later the gauge was back to reading normal again.
06-30-2019, 09:55 AM | #15 |
Think I’ve got it solved. The copper pad connector to the plug on the instrument panel pcb was crumpled up and shorting to the next pad which went to the hot temp light where I had put a bulb in for some reason. Also cleaned all the connections at the gauge. Took a short drive and it seems to be working much smoother
06-30-2019, 09:57 AM | #16 | |
