01-25-2008, 12:40 AM | #1 |
52 chevy brakes
Hy, new to the forum here!
I have a 50 and a 52 chevy truck and have some queations ? I put a dual bowl mastercylinder on the 52 with 2 10lb residual valves and changed the mc twice and still can only get about a 1 1/2 pedal on the brakes.It has a drum -drum set up. And on the 50 i cant get the hood to shute allthe way down like it should no matter how i try to adjust it? Any ideas??? |
01-25-2008, 12:42 AM | #2 |
Re: 52 chevy brakes
O.k. Your brakes first. Where and how did you mount the master cylinder?
Second, you said you placed 10 pound residual valves. i am assuming you may have bolted it under the floor, Is this true. Where did you get the master cylinder?
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
01-25-2008, 10:38 AM | #3 |
Re: 52 chevy brakes
The mc is in the original spot under the floor .
The mc came from a 77chevy truck[manual],new from the auto parts store.It is the second one i have tryed and still the same problems.The brakes work great but have to pump at least 1 1/2 times to stop? |
01-25-2008, 01:07 PM | #4 |
polishing a turd
Re: 52 chevy brakes
are you losing fluid?
have you bled the brakes and the master cylinder? it sounds like either air in the system or a leak.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
01-25-2008, 01:16 PM | #5 |
Re: 52 chevy brakes
No leaks and have been bleed numoris times ,and even whith a hand pump bleeder and still same results .
I really dont understand it .My 50 has a camaro sub frame with disc's and thats the only differance betreen the two trucks and the 50 has awsome brake's? It's got me stumped???? |
01-25-2008, 10:29 PM | #6 |
Re: 52 chevy brakes
Sounds to me like your residual valve is not maintaining pressure. What kind are you using and where are they placed in the brake circuit?
Kateaux |
01-26-2008, 12:38 AM | #7 |
Re: 52 chevy brakes
I'm useing a speed way in back and a wilwood up front.they are located midway on back and just after irt comes out of themc up front.
Thank yall for trying to help out! |
01-26-2008, 01:05 AM | #8 |
polishing a turd
Re: 52 chevy brakes
is the mc push rod adjusted properly?
01-26-2008, 01:07 AM | #9 |
Re: 52 chevy brakes
I beleive so.
but how do you guys adjust yours? |
01-26-2008, 07:00 AM | #10 |
Re: 52 chevy brakes
The residual valves are directional, are the in's and out's in the right direction? Is the pedal giving enough travel on the plunger into the MC?
K8O |
01-26-2008, 08:14 AM | #11 |
Re: 52 chevy brakes
Yep,yep,and yep.
Thats why i dont understand either? |
01-26-2008, 10:48 PM | #12 |
Re: 52 chevy brakes
I wish I could be more help...try this http://www.mpbrakes.com/technical-su...leshooting.cfm
I'm not 100% sure but I think there is a difference between power master cylinders and manual. Also between drum and disc.
'56 truck (the never ending project) '06 Z/71 loaded (daily driver) '07 Mercedes-Benz C-Class (wife's driver) Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod, |
01-27-2008, 01:57 AM | #13 | |
Re: 52 chevy brakes
