08-12-2020, 06:36 PM | #1 |
Well I bought another one
Bought this 66 back in February early March . Was planning to go down to Sacramento in April and trailer it back home but with covid and borders closing I finally decided to get it shipped up as the border doesn’t look like it’s going to open anything soon.
I hate buying things over the net but this truck looked really solid from all the pics and a big back window, short fleet plus the colour I really like I couldn’t pass it up. Other words I really got sucked in 🤦*♂️ It’s all there pretty much , 283 4 speed. Motor did run before being parked. I should have it in 2-3 weeks hopefully. Here’s a few pics |
08-12-2020, 06:43 PM | #2 |
Re: Well I bought another one
Nice! Going to drive as is, or are you going to give it a fancy paint job?
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-12-2020, 06:51 PM | #3 |
Clean it up and drive it as is for first bit. Preserve the outer paint and metal like my other 2 trucks and depending how much rust i find I'll gut inside cab metal. I'll see once i dig into it . Update brakes, steering maybe ls swap this one as well with a 6 speed though Im thinking
08-12-2020, 09:53 PM | #4 |
Sounds like it's going to be sick!
08-13-2020, 02:20 PM | #5 |
Very Nice and I dig that side view mirror too. Congratulation!
MusicMan70 1961 GMC Suburban |
08-13-2020, 04:16 PM | #6 |
Someone posted this for sail add that you might be interested in.
08-13-2020, 04:31 PM | #7 |
08-13-2020, 04:47 PM | #8 |
Thanks! i been collecting parts already. Cant wait to get started on it. I told the wife this will be the last one lol. Ill sell my 65 if this one is in great shape I'm running out of room at home. I been looking for a matching west coast junior mirror but no luck . I did find a nice set of similar mirrors on here though just alittle bigger.
09-18-2020, 09:20 PM | #9 |
Finally got my truck home early last week and got to clean it up and get it running. Was last registered in 91 spent its life in Sacramento as a farm/ranch truck and Chico CA looks like. I found some registration papers in glove box from 91
I was alittle stressed wandering how solid cab metal was as guy didn’t go out of his way to take many pics for me but was pleased to find floor and cab mounts etc are very solid and there is hardly any rust down low �� Gave her a good cleaning, through a hei distributer in for time being and she fired right up pretty much. Found a rusted out frost plug shorty after running it then after that found a leaking head gasket. Clutch was seized up and broke it free and was driving it alittle by my shop . Found most of the build sheet under the seat and truck has quite a few options. Power assist steering , sway bar, custom comfort option there’s a few codes I’m still trying to figure out from the build sheet . The ac system looks to be maybe installed by gm afterwards. The holes in the rad support and in the firewall look to be factory punched out holes . Not sure looks like it has a smog pump on engine too. Anyways here’s a few more pics of her. The plan is to pull engine fix a few odds and ends brakes etc and drive it . It’s a pretty original truck I have two others with ls engines turbo etc but this one is too original and unmolested and it’s going to stay that way. Last edited by jrusher; 09-19-2020 at 04:10 PM. |
09-18-2020, 09:38 PM | #10 |
Few more pics. Starting doing a cut and polish need to get rid of the white spray bomb paint somebody went to town with
09-18-2020, 09:50 PM | #11 |
Great find!
Posted via Mobile Device |
09-19-2020, 02:50 AM | #12 |
Just here to tinker
Looks awesome! Great original truck.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-19-2020, 07:45 AM | #13 |
Moderator
Love it, great find.
09-19-2020, 12:37 PM | #14 |
Nice find! Original issue '66 California black plates ( note starts with U ). Sacramento has a very dry climate, appears to only have the typical Calif. water retention damage from clogged drainage holes. That steering wheel is missing a lot of paint, will look nice when the wheel color matches the column color! Interesting it was ordered with a 4 speed instead of a 3 speed or auto.
09-19-2020, 03:56 PM | #15 |
Thanks guys! Was a big gamble buying it site unseen and costly getting it up here but it all worked out 😁
Here’s a pic of the farm info on tailgate |
09-19-2020, 04:04 PM | #16 | |
09-19-2020, 04:27 PM | #17 |
Very nice condition, along with great color. Agree it will look outstanding as an original truck.
Member 60-66 can likely tell you more about the A/C. It has a 3 row radiator. Does it have shoulder belts? Last edited by aotte1; 09-19-2020 at 04:38 PM. |
09-19-2020, 07:36 PM | #18 |
Right on great. Ill have to research all the Ac info. Be nice to get it all working one day . No shoulder belts just lap. I thought the nut or insert would be in panel above shoulder but it’s not
09-20-2020, 12:13 AM | #19 |
What A Beauty What a Score
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
09-20-2020, 10:42 AM | #20 | |
California Farm Bureau Federation is a nonprofit organization of farmers and ranchers consisting of county Farm Bureaus from nearly every county in California, established in 1919 to work for the betterment of family farmers and ranchers in California. We are deeply committed to our mission, which is to improve the well-being and quality of life for California farmers and ranchers. We do this through advocacy, ongoing outreach, and economic services and products for those involved in agricultural production. |
09-20-2020, 10:48 AM | #21 |
purely a gem find!!
09-20-2020, 12:38 PM | #22 | |
09-20-2020, 01:24 PM | #23 |
Just here to tinker
I just realized your in AB. I actually grew up in Sacramento, CA and I used to date a girl from Medicine Hat. One time we drove up to Edmonton to see her brother....that stretch of 1 has to be the longest, straightest road I’ve ever seen. I thought I was trapped and it would never end! Hahaha
09-20-2020, 05:03 PM | #24 | |
09-23-2020, 09:35 AM | #25 |
Sweet truck...excited to see your progress
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
