04-13-2021, 11:45 AM | #1 |
1970 C30 C&C weight
Well, it's been a while since I've been on here. I have a 1970 C30 cab and chassis that I need to ship from Colorado to central Florida. It has no engine or tranny. I need a good guesstimate on the weight for the shipper. All responses appreciated, I need to get'er done. I'd also like to know if anyone knows a good reasonable shipper. It's about 1800 miles. I have used uship before but sometimes you can catch a ride with an open slot. The truck is 20 feet long 6'6" wide without the side mirrors mounted.
04-13-2021, 08:52 PM | #2 |
Re: 1970 C30 C&C weight
What kind of wheel base does this have? GVW? No engine or trans I would guess between 4-5k
04-13-2021, 09:21 PM | #3 |
A 1970 C30 rolling chassis with cab and NO drivetrain, NO front end sheet metal, and NO bed should weigh under 3000 pounds.
1971 SWB step side: Original NM Forestry and then NM Fire truck Last edited by Carl Spangler; 04-13-2021 at 09:27 PM. |
04-13-2021, 09:49 PM | #4 |
I'm pretty sure it has an Eaton on the rear. It was a camper conversion. I don't know the wheelbase but from the pics it appears to be a couple feet longer than a regular flatbed dually. The front clip is on it. I think I'll look up the weights on the engines and tranny's and subtract. I don't know the GVW, I'll see if he'll send me a pic of the spid tomorrow. I think the GVW's in the spid numbers.
04-13-2021, 11:17 PM | #5 |
From memory (not super reliable)... my 152” wb c&c was about 4,200# at the scales. Without the drivetrain I can see it getting close to 3k.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
04-13-2021, 11:25 PM | #6 |
Wheel bases avail 127''---133''---157''
My 69 what once was a 'class B' motor home is 157'' wheel base. Had an HO72 in it |
04-13-2021, 11:27 PM | #7 |
I found it at oldride library. They cover them all except V8's. Mine's the 2nd one down. 1 Ton - Model C - Series 30 - 133 in wheelbase
CS31002 - Chassis & Cowl - - 138 CS31003 - Chassis & Cab $2,735 3,641 lbs 14,873 CS31034 - Fleetside 8.5 ft. $2,935 4,157 lbs 1,404 CS31004 - Step-Side 8.5 ft. $2,875 4,071 lbs 2,101 Last edited by prateroad; 04-13-2021 at 11:51 PM. |
04-14-2021, 03:02 PM | #8 |
