Old 07-09-2022, 08:33 AM   #1
70cst
70cst's Avatar
Which is best for thermal protection of your starter?
Yesterday I experienced a couple times where my starter wouldn't engage due to heat build up. From you experience which is better"
1) a Heat shield
2) Heat wrap – looks to be cheaper to buy
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-09-2022, 08:41 AM   #2
72SB
Re: Which is best for thermal protection of your starter?
Heat wrap, IMHO, would work better but either is a band aide. Your battery cables need to be solid and starter in good condition. Check voltage while cranking at the starter wires on solenoid
Headers??
also a gear reduction starter (aka mini starter) will crank faster and if you have a higher than stock compression motor works better. Rockauto is where I get mine.
X reference for Remy stock type to their GR type. IIRC mine was around $70
File Type: pdf Starter-6-RemyTechnicalBulletin_Feb2016_web.pdf (230.5 KB, 43 views)
72SB is offline   Reply With Quote
Old 07-09-2022, 08:44 AM   #3
geezer#99
geezer#99's Avatar
Tried them both.
Neither one worked.
Converted to a remote style solenoid. Never a problem again.
Old 07-09-2022, 09:00 AM   #4
I have headers and I use a newer style starter, also known as mini-starter. They do spin faster and that helps. But what makes them work well and last is the air gap from the heat source due to it smaller size. A remote solenoid is the way to go when keeping the original type starter and not running headers. I never used heat wrap because I don't like adding extra aggravation to servicing my vehicles.
Old 07-09-2022, 09:07 AM   #5
ga-stepside
ga-stepside's Avatar
Originally Posted by geezer#99 View Post
Tried them both.
Neither one worked.
Totally agree with the remote solenoid. The problem is the purple wire from the ignition switch to kick the stock solenoid can't carry enough current when the stock solenoid gets hot.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 07-09-2022, 09:30 AM   #6
70cst
70cst's Avatar
Thanks for the info...
Old 07-09-2022, 06:34 PM   #7
Sheepdip
Sheepdip's Avatar
Tried them both.
Neither one worked.
^^^^^^^^^^^^This works every time^^^^^^^^^^^^^^^^
Sheepdip is offline   Reply With Quote
Old 07-09-2022, 07:11 PM   #8
franken
The starter not engaging is a more a solenoid issue than starter issue.
Measure the voltage to ground (metal body of the solenoid) at the S-terminal while the key is in the start position.
Old 07-09-2022, 07:14 PM   #9
Accelo
Accelo's Avatar
Confirm the battery is good with a load test. Even new is suspect, learned that lesson the difficult way.
If you know how to do a voltage drop test check cables, post to clamp and most importantly the negative post to the block. Confirm all the grounds are in place and even if they are add some more. Its an impossibility to have too many.
If that doesn't work purchase a quality solenoid. It may cost as much as a Rebuilt China starter!
Repaired a lot of starter issues with these simple functional tests.
Measuring low resistance with the voltage drop test is the only method that works reliably. If you don't know how there are lots of tutorials on YouTube. The test is completed while the motor is rotating using the starter. You can pull the coil wire to keep the starter engaged while cranking.
Cheers
Accelo is offline   Reply With Quote
Old 07-09-2022, 07:26 PM   #10
jumpsoffrock
Do you guys advise using a simple old Ford style solenoid?
jumpsoffrock is offline   Reply With Quote
Old 07-09-2022, 08:27 PM   #11
LS short box
I don't know if it will work for you but all the LS type engine starter solenoids come with a metal heat shield that clips over the top of the solenoid. I always add a piece of DEI heat shield self adhesive type to it for a little extra heat protection.
Old 07-09-2022, 08:34 PM   #12
jimijam00
3) Header delete.
jimijam00 is offline   Reply With Quote
Old 07-09-2022, 08:48 PM   #13
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I have been using a starter from a 96 454 Suburban. The problem has gone away.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-09-2022, 08:50 PM   #14
geezer#99
geezer#99's Avatar
Originally Posted by jimijam00 View Post
3) Header delete.
Won’t matter!
I’ve had the problem with both headers and converted back to stock iron manifolds on the same motor.
Ford solenoid cured it.
Old 07-09-2022, 09:07 PM   #15
3) Header delete.
Good advise... for yourself. I'm pretty sure the truck in this thread already has manifolds. I'll stick with what I like. Been running headers forever on more vehicles than I can count. I've had hot problems with one truck running 15 year old headers needing a collector gasket (original from header installation) replacement.
Old 07-09-2022, 09:20 PM   #16
jimijam00
Old 07-09-2022, 09:46 PM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
I was chasing a hot start issue.
And... and found green death in my starter cable.
Old 07-09-2022, 10:02 PM   #18
rockyrivermark
For me a mini high toque starter solved that issue.
Heat from headers.
The small start we created enough clearance.
$124 for summit brand.
rockyrivermark is offline   Reply With Quote
Old 07-09-2022, 11:24 PM   #19
'68OrangeSunshine
'68OrangeSunshine's Avatar
Tried them both.
Neither one worked.
I was about to say the same thing.
On my V8 equipped '71 GMC Jimmy, I would have to pull the passenger side headers off to change out the starter or solenoid. Haven't needed to mess with it in years.
Old 07-10-2022, 08:30 AM   #20
70cst
70cst's Avatar
Thanks Again
I do not have headers
Old 07-10-2022, 08:31 AM   #21
70cst
70cst's Avatar
If I went with a solenoid ... any particular solenoid - with mfg and number? Thanks
Old 07-10-2022, 10:06 AM   #22
Sheepdip
Sheepdip's Avatar
A good relay such as Bosch or a ...ahem...F*rd starter solenoid is the most popular. Both mounted up on the firewall or inner fender.
Old 07-10-2022, 10:06 AM   #23
SRU1436
I use one on my Chevelle, which has headers. Works great, no heat issues with the starter.
SRU1436 is offline   Reply With Quote
Old 07-10-2022, 10:09 AM   #24
SRU1436
I have this one on my chevelle, this one is new. The car had an older no name remote solenoid on it but it eventually quit working.
https://www.summitracing.com/parts/QCR-50-430
Old 07-10-2022, 10:40 AM   #25
I apologize for getting snippy, jimijam00. I just get tired of hearing that broken record. And in this case your comment didn't even apply. People have different experiences and maybe I'm just lucky. But if headers had been the problem so many claim (or learned from hearing others so often) I wouldn't have been running them all these years. The proof is in the pudding for me
